Anyone can compare Matrix X-SPDIF 2 to M2Tech Hiface Evo 2?
I has Singxer Su-1 but ive change it to Evo2.
something like this is perfectAwesome. Any hdmi cable recommendations for the I2S?
I am using one of these Moshou HDMI as an i2s cable and works well (0.5M). I believe this is the model recommended by some guys at the Audio-GD DI-20 thread. My guess, evolved through at least 6 years i2s experience, is that as long as the cable has basically good construction, meets the HDMI spec, and is short (0.6M or shorter), then sound quality will not be significantly compromised. I also have and had some higher end Wireworld models (one in another system currently), Silversonic, etc. but do not feel the need to even test for differences at this time as the Moshou seems to me to be doing a great job. Since you may need it quicker, note I have often picked-up an older WW version very cheap.. my guess is the short lengths are relatively more difficult for them to blow-out when the model changes. Be careful on checking the flexibility required, and generally it is not recommended to attach/detach i2s connections while either of the send-receive devices are powered up.Awesome. Any hdmi cable recommendations for the I2S?
https://www.ebay.com/itm/Moshou-Enthusiast-HDMI-2-0-Cable-4K-60Hz-18Gbs-High-Quality-Silver-Plated-Core/202712850056?ssPageName=STRK:MEBIDX:IT&var=502838276291&_trksid=p2057872.m2749.l2649
I'm using a 3ft bluejeanscable and it works fine.I see, so considering proper construction, just making sure that it is .6m or shorter is all that is needed? I planned on getting a 1m cable.
Just got quick response from Matrix Audio:I have matrix audio X-Sabre (1st gen) dac and X-SPDIF2 connected by AES cable, playback from Macbook. Regarding MCLK switch on X-SPDIF2, I am not sure if I should turn MCLK to "ON" or "OFF" position, please help. Thank you.
Compare to Eitr. Is the price/performance worth it?
