SilverEars
- Sep 18, 2013
Ok, I was curious enough if measurements can tell us how the well the DACs perform sonically. My logic initially was, if X-Sabre Pro sounds good and measures good, why not another DAC that measures good perform just as well?
This is where Topping D90 comes in, and what a disappointment it was. It's nowhere close to performance of the X-Sabre Pro, and I would not drop that much for such level of performance, and would rather go with a much cheaper Schiit DAC or if want to be fancy go for Bifrost 2 or higher. For the kind of mediocre performance of D90, why not just buy a dirt cheap DAC?
So, the lesson is that measurements do not correlate directly to the performance of a DAC. Topping is no where near the imaging and resolution performance of the X-Sabre Pro.
After this, I probably will not look at another Topping again. It seems Topping was raising their price by raising hype of pure objectivists that cannot tell DACs apart sonically.
Hear and look at measurements, not look at measurements and not hear. So, I would not look at a SINAD ranking chart and assume the higher ranked is the best sounding. That would be a BIG MISTAKE people can make and put down hundreds on mediocre sounding DAC. Smarter people actually compare by hearing, not by assumptions from data that doesn't give the complete picture.
I guess good stuff can come from China. Who designed the X-Sabre Pro?
