ADUHF
Headphoneus SupremusMusic And Measurements
All recordings have the same maximum sustained peak level. That is the maximum comfortable volume you set it to with your amp....
...I might not be explaining that clearly. But I'm trying.
You're doin fine bro. I guess sustained peaks are different than average sustained levels. Hence the confusion.
Another way to look at it would be peak comfortable listening volume. For the loudest sustained peak level, that would be about 80dB. Add 10dB for a transient peak here and there and you are at 90dB. If an amp can produced 90dB, you should be fine. Anything over that would be overkill.
I'm not sure how this fits into the equation, but a figure I've often run across on sites like Gearslutz is around 85 dB. I'm not sure if that's for mixing or mastering though. And whether that includes the headroom that you all are referring to. This would be for loudspeaker monitors in a studio btw, rather than headphones.
I would think that the approximate range used for 0 dBFS for mastering might be more relevant to this question than the range for mixing though.
