ADUHF
Headphoneus SupremusMusic And Measurements
Quick follow up question- I understand the math and thanks for explaining it in this manner. Greatly appreciated. When we are talking about headphones being driven, is the mW value the most important thing to consider or must we also consider voltage? For example, do high impedance cans benefit from both a good amount of mW (such as 1/3 Watt or higher) and a certain minimum voltage? I am still curious if there's a standardized definition of "driven".
This is just my uninformed opinion on the subject. So take it with a grain of salt.
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
I think the power in watts or milliwatts is probably the better gauge though when comparing the sound levels of different headphone+amp rigs. That seems to be the figure that's most often focused on, in these kinds of discussions anyway.
I believe that dBs per volt is good for comparing the relative loudnesses of two different headphones. But that should tell you why volts are probably not as good for comparing the overall levels of different headphone+amp rigs. Because one headphone may sound quite a bit louder or quieter than another when receiving the same signal voltage. Due to their differences in sensitivity and impedance.
It is possible I have this all in reverse though. So I'd like to hear some other opinions, to see if others agree or disagree.
I think watts or milliwatts should give you a better idea of the overall output of the rig or system in decibels than voltage though.
