I always appreciate the help with the math and science. I'm really not a master or expert on that stuff, so it's always a little awkward for me to poke my nose into these conversations as if I know what I'm talking about. But, like you, I like to help where I can and it seemed like a question was asked that I (more or less) knew the answer to. I used to let people know the limits of my understanding straight off the bat, but that just made people assume the math was just another opinion on the Internet and therefore something to be argued with. Now I let people assume I'm an expert and then be embarrassed by it later.
I'm perfectly willing to admit that 120dB is completely ludicrous. I'd like to actually measure how loud I listen, but I really don't want to buy I measurement mic just so that I can do one measurement once, just so that I can look more like an expert on the Internet.
There are always risks involved in stepping into convos like this. So it is appreciated when people are willing to make the extra effort to do so. You are all top notch in my book!
The empirical validation is much appreciated here, as I'm learning. Great discussion.
While we were all doing our math homework, I had sent a message to Matthias Carstens, who is the head of RME product development, asking him if the ADI-2 can sufficiently drive 300 Ohm headphones (e.g. HD800, ZMF) and his reply: "Of course it can."
I'm going to go ahead and trust the math, the head of product development from RME, and my own ears. That being said, I will continue to test drive separate amps, listen for myself, and see if I can note a preference towards a separate amp or the RME.
I am still trying to better understand the effects of power, voltage, current, impedance (both source and load-related) and damping on a headphone's sound quality. And the best ways of optimizing all the above.
Part of the problem is that I still don't have a really good grasp of all the fundamentals of how headphones and amps work. And need to do more reading to get a better understanding on this. These are a few things (I think) that I've picked up both from the discussion here and looking at other info elsewhere though....
More power = more volume in a headphone. Since power = both current and voltage though (technically multiplied, rather that added), you can potentially get more power or volume from either one. An amp varies the amount of power or volume of a headphone by varying the voltage it can receive though. So an increase in voltage also = more volume.
Amps will deliver different amounts of current to different headphones, based on their impedance. But for a given load impedance, the current should always be more or less constant. So the power/volume is always varied by the amount of voltage that particular pair of headphones receives. (There are some amps which can vary the power and volume by varying the current rather than voltage, but those are special cases.)
Amps and headphones are connected in series. Which means that their impedances combine. And more impedance on either the source or load means there is less current between the two.
What I'm still having some trouble understanding though is why it seems easier to drive both low and high impedance headphones to higher volumes with a higher impedance amp, rather than with a lower impedance amp. Because the lower impedance amp should allow the headphone to receive more current.
The headphone amps that I've used in the past always had somewhat higher impedance, generally more in the 20 to 50 ohm range. But somehow they were able to drive both types of headphones to higher volumes, even though they are (apparently) outputting less current. How is this possible? Is it just because they have alot more voltage?
