bigshot
And reserving 10dB as a headroom would more than cover any reduced volume caused by EQ.
Right, but I'm saying that you need a 10dB headroom on your amp over maximum normal listening volume. The added 10dB headroom would give you room to double the weaker signal.
Here is the question I've been answering...
The question was how much headroom does an amp need properly render transient peaks? I pointed out that 10dB more than covered that. Now we're talking about EQ. 10dB is enough to cover that too.
For playing back commercially recorded music, a 10dB buffer over the amp's maximum volume is plenty enough.
On my AVR, the volume is measured in terms of -dB below zero, which is the theoretical limit of the amp. Generally, I play modern movies (which are more dynamic than most music) at -9 to -15dB, depending on the level of the soundtrack on the disc. I've never run into an instance where my amp was insufficient.
You can go ahead and buy an amp as big as Hoover Dam, but it's not going to make any difference. When it comes to headroom, enough is all you need. That's true of a lot of things in home audio... frequency extension, transparent noise floor and distortion, lossy audio artifacting, etc.
Audiophools are always hedging their bets, arguing that enough is never enough. "If a response that goes to 20kHz is good, then one that goes to 40kHz must sound better, right?" "If I gain ride the fadeouts on songs by a massive amount, I can hear the digital noise floor- therefore a noise floor below -120dB is necessary." "I used to have an amp with .01% distortion. Now I have one with .005% and it sounds much better." You can see bologna like this in a lot of the threads on Head-Fi. One person mentions a threshold of transparency or recommended spec and then all the armchair experts try to think of a rare exception that might mean that figure is a little too low. Then another armchair expert tries to one up the first armchair expert by mentioning an even more unlikely exception. Again and again until we are running down a rabbit hole into La-La Land. It has nothing to do with how an amp or DAC actually performs in the real world. It's all inside of people's heads. It's ego gratification. They aren't actually helping anyone put together a good sounding stereo system. "I'm not a doctor, I just play one on TV."
The 85 dB reference level is supposedly fairly loud though. So most folks actually listen at about -10 dB (or even lower) below that. Which would put any 0 dBFS transients more in the 95 to 105 dB range.
The difference between equalized and unequalized levels are often so big there are several EQ plugins that offer loudness compensation for a better A/B-ing so you don't get distracted by the difference in levels and pick the louder one by default. Obviously it depends on how you use the EQ but it's used in this way often enough to warrant this function.Fwiw, your comments about EQ make some sense, if you're going by the volume of an amp based on listening. Perhaps less so, if you are using measurements, because the goal of EQ is generally to make the loudness more uniform across the frequency range at your target dB level.
I think bigshot's point on this is simply that the change in overall levels between an EQ-ed and un-EQ-ed headphone would generally be too small to make a noticeable difference in the sound performance, even if you have to raise the amp a few dB's to compensate for the equalization.
I'm sure you are not actually interested in my explanation so I'll just bring an example and you can check if it holds true for your usual cases as well.How would EQ increase the dynamics of transient peaks?
https://en.wikipedia.org/wiki/DBFSFwiw, this was my final though re the 85 dB at -20 dBFS reference listening level...
The 95 dB figure above is pretty close to the level that you have suggested for sufficient headroom. So it seems to me that we are pretty much on the same page on that.
I believe that 85 dB (with a -20 dBFS signal) is the target dB level for unity on the master volume control though on alot of home theater setups. So that is what I would personally try to aim for in my setup. The chances are remote that you'd ever need that much volume in normal listening though.
As stated above, most people will set the master volume on their HT systems more in the -10 (or lower) range when listening normally. Just as you are doing on your amp. Which means the effective headroom will be closer to the 95 dB range in the treble and midrange. And up to about 105 dB in the bass. And the level for a -20 dBFS signal will be around 75 dB.
Maybe this is all wrong though.
It's unlikely a track would sound more dynamic after the EQ + normalization back to 0dBFS, however it still would sound quieter.I know that EQing subtractively lowers the volume level. But couldn't you just normalize the equalized track back up to zero and it would have the same basic compression and overall perceived volume that it had before?
It doesn't undo compression. Compression reduces dynamic range in a very specific and easy to understand way. EQ just changes the dynamic range and although the changes in dynamics can be predicted from the input and the actual curve it is not intuitive at all.I don't see how high levels of compression can be undone by EQ. If you could just explain how that can happen in laymen's terms it would help me understand.
As a consumer, you will get a properly mastered track. For a lot of genres, this means whatever you get got passed through a limiter as a last step. Even though the limiter operates in the time domain, the end result can be viewed at as a specific balance of frequencies. If you change that balance with an EQ during playback, it will reintroduce some "dynamics" but not the kind that was there before the limiting. This effect will be most likely perceived as reduced volume not as bigger dynamics along with the increased/reduced bass/mid/treble depending on what the EQ was intended to do in the first place.Some of the stuff you were citing above were referring to a mix, not playback of a commercial CD.
If you look at the waveforms I posted, you can see that I normalized to EQd signal back to 0dBFS but still, the overall level decreased.
