srinivasvignesh
- Dec 3, 2015
Thanks for sharing that information. Do you have the Symbio W's or the F's?
W
I did a video review on the MW07 GO, I hope it is a ton of fun to watch!!
I have posted my video review about the MW07 PLUS as well now!
I try my best to compare the GO vs the PLUS version, and I will also add a video about the MH40 wireless soon!
Thanks a lot, for the comparison between the Plus and GO versions especially. I was on the fence as I really want new TWS only for the gym, and the GO use the same driver and are lighter so it seemed like a good compromise since the price point is friendlier. But if the Plus sound substantially better, while also being well-rated IP-wise, looking killer, and canceling out some of the gym noise, they are probably a better choice for me since I want to compromise on neither SQ nor aesthetics.
Yes! There’s that too. Although truth be told that fragile stainless steel case troubles me a bit, as it’s not very gym-friendly even if I’m cautious. It’s more for sedentary use. But it’s really good to have so many more hours in the case obviously, and the IPX5 rating on the buds is really good.Don't forgetting that you are getting more hours in the metal case too with the Plus model.
They have thought of everything it seems! Thanks for your input. How would you compare the MW07 Plus to wired iems if I may bother you further? And have you heard other TWS sets that compare favorably to them?The (beautiful!) metal case is strong but is very easy for scratching, but maybe this is looking nicer in the future like patina effect in some metals for example. But the good news, if you want keeping in perfect condition, is that is coming in the package a separate plastic pouch with magnetic closure for protecting the metal case if you are outside.
Thanks for the extensive reply.In the past I trying many wired iems and is difficult comparing today with this many iems. Today I think tws iems are excellent and the difference with wired and wireless isn't really easy hearing for the people. I'm sure in blind test this is true even if many people here telling you wired is much better sound. This is similar with blind tests in the past with different bitrates or blind tests of the burn-in effect. This tests showing that bitrate higher than 192kbps (and even 128kbps!) isn't easy for the people for hearing the difference between this and lossless (is more true even specially with 256kbps). With burn-in is similar, the people cannot hearing the difference and the measurements showing burn-in isn't real in 99.99% of the times. So, today, tws iems are sounding very, very good, but the real difference is in the tuning, the frequency response/tonal balance.
The mw07 plus isn't flat / neutral but the tuning by master & dynamic is with very good taste specially if you're outside where some frequencies are more difficult hearing because of the external noise. BUT in quiet places is sounding excellent too! The driver they're using is of very good quality too.
Other important tws iems I trying before are (I trying some cheap that aren't good and I don't mentioning here): sennheiser momentum true wireless 1 (mtw 1) and the recent model mtw 2, the excellent AirPods Pro and the recent Jabra 75T (I think this is the correct model). The Jabra is very, very bassy and really isn't for me. Sennheiser mtw 1 & 2 having the same very, very good sound, but I preferring mw07 Plus sound than mtw 1 & 2 because I preferring the more clarity and fast bass performance of the mw07 Plius.
The 2 models of sennheiser having other problems (specially bad problems with model 1), like low battery life (sennheiser saying the better model 2 is giving you 7 hours and you only getting 5,5 hrs with mid volume in reality).
The AirPods Pro is have more flat / neutral sound and fantastic anc and ambient mode AND small very practical portable case, but battery life isn't very good and the sound isn't sufficient engaging, in my opinion. I know a lot of people liking saying Apple earphones are terrible but believe me, the AirPods Pro is excellent iem, also in the sound. BUT for me the mw07 is the best in sound and the complete package (the other aspects apart from the sound).
With many months now with mw07 Plus I can saying that one fantastic aspect of this iem is the external buttons, nothing is like this iem in this aspect. You can controlling many things with this buttons and they are responding so, so good and never making noise when you click them. I changing tracks and volume very frequently and this buttons are perfect like nothing I trying in the past, even with big headphones
What’s your take on the MW07+’s noise cancellation? In the street especially, or in places with ambient music.
I’m using creative Outlier Air at the moment, they are decent, really good for their price point, with fun, massive sub-bass, but also bloaty and too recessed in the mids. I have a long-ish walk to and from the gym, so I use my wired iems plugged in a good source, and the difference is getting too jarring. Also the construction and design are functional but nothing exciting.
I tried out the Nuraloop but that didn’t pan out. Catastrophic touch controls, SQ good not great in spite of their cool technology, comfort not quite there either.
The entire M&D store is 25% off this week-end, and for a cause. Time to snag me something, methinks.
Can anyone give a more detailed opinion on the ANC? From the reviews and comments, its not amazing, but does it do an ok job? I listen to a lot of podcasts and audiobooks (as well as music) and this issue that I have with my current wireless non-ANC earphones (Flares Pro) is that I need to have them on full volume to be able to hear them over traffic noise when I am out. This is the reason I am getting rid of my Xelento Wireless as they have become purely indoor earphones as they are useless outside due to virtually no noise isolation.
