I actually use the 789 mostly with my Focal Elex, but I did try it out with the Aeon finally this week during the holiday. Was also pre-occupied with the Focal Elegia's that I had for a week and sent off to the next user on Tuesday.
I think the Aeon sounds absolutely pristine with the 789. I've been listening to some Christoper Lawrence lately as it's pretty bass heavy and fun to play at louder than normal volume, so a good test for your query.
With my Aeon on the lowest gain setting, I was able to play at full volume with no distortion, but not quite at the limit of what I think is loud. It's pretty loud, but I show them on about 2pm in the second picture, and that is about where I think it sounds about ten percent more volume than the full on no gain and about as loud as I need to go. This amplifier still has more ooomf to give, but don't need to blow my ears out either.
The Audio-gd at lo gain I get about 65 on the volume knob to get the similar volume to the 2pm mid-gain on the AAA. The Aeon requires significantly more power than say the Focal or Sennheiser by about 40%. Especially the Elegia which is closed too, and very forward sounding but super efficient. I don't think you'll likely have to use the gain much as I usually am content to listen to the low gain settings on all my amps as they sound great at lower levels enough so that the music it's not ever not loud enough or too loud.
The amplifier is absolutely silent even with the volume all the way up. The Mr. Speakers are just excellent all around, and after listening to the Elegia's (also closed) I'm more than ever convinced that they are the better of the two by a significant margin and pairs great with this amplifier as it's very powerful, and wasn't as needed for the Focal. The AAA is very transparent, and it seems to have great bass and sub-bass performance over my other amplifiers with the exception of the NFB-1. I think the 789 is superb. Either way, there no perceivable difference to me between the gain stages of this amplifier, so if you need to play it louder, don't sweat it. It's just great.
