schmalgausen
I have a marble version
What is "version" for 58X?
The marble version is a pair of original HD600, not HD58x.What is "version" for 58X?
I have one (not 3 meters but the shop I was shopping had many options) silver coated copper which I bought from ebay for 22£ total.Fwiw, I'm glad that 1st party cables for the HD6XX series are so widely available, of decent quality, and inexpensive to boot. Recently got a new integrated amp for my living room with a high quality headphone out and I'm enjoying listening to my 58X through it. Access to an affordable aftermarket 3m cable from Sennheiser is ideal. Along those lines, I wish the 4.4mm pentacon cable that comes with the 660S was more widely available.
Hart Audio made me a great cable for mine, which not only sounds great but lets me switch back and forth between terminations depending on what I'm hooking up to.Fwiw, I'm glad that 1st party cables for the HD6XX series are so widely available, of decent quality, and inexpensive to boot. Recently got a new integrated amp for my living room with a high quality headphone out and I'm enjoying listening to my 58X through it. Access to an affordable aftermarket 3m cable from Sennheiser is ideal. Along those lines, I wish the 4.4mm pentacon cable that comes with the 660S was more widely available.
Interesting info thank you for sharing. Can you install 660s drivers instead?I damaged the drivers of my HD58X and tried to get new ones.
After a lot of email contact with Sennheiser , Sonova and Massdrop I found out that this driver (System 150R) is not available as spare part.
Maybe this was already mentioned by someone before but I didnt read every post.
Here the final comment from Massdrop: "If it is under warranty then yes we would replace the headphones, we do not offer repairs.
We are unable to sell or send individual parts for our products. We have no suggestions other than buying new headphones".
May I ask again who exactly said that 58X is using the 150R system ? (or at least a variant for th3 58X headphone) Sennheiser/Sonova or Drop?I damaged the drivers of my HD58X and tried to get new ones.
Did the swap work? I also want to try thisFrom a cursory Google search, I'd say they're not that easy to get, but even if one did, it still might not look as premium because I believe there is a thin piece of foam obscuring the view, unlike in the HD 600 and HD 650.
Here's the 650 and 58X side by side. I just think the 650 (and the 600) look so much more "high-tech" and premium showing off the internals, than the 58X does with its cheaper-looking grill (and foam) hiding them.
I have not tried but is very possible to work as these have interchangeable parts.Did the swap work? I also want to try this
