IkSak
The Magni 3 and Tidal HiFi are good combo for the Elex. I run that setup at my office and they sound good. Just make sure to pick good recordings
Boy it does!!! Today I listened to two different versions of the same recording, one that was remastered and difference was like heaven and Earth!
One curious thing is that despite the sensitivity and the impedance, the Elex does like power. I've settle to use it in high gain with the schiit Magni 3 and Vali 2. Have you had a similar experience?
Also, which amps have you pair the Elex with?
No, the Elex aren't particularly power hungry. The signal chain you describe--high gain on a Magni 3--leads to dynamic compression. With compression, everything has pretty much the same volume and music tends to go soft or muted when it would normally go loud. Compression works against the core characteristic of the Elex, which is precise and expansive dynamics. Large volume differences within a song do not indicate the need for more power. The native Elex signal can indeed sound "weird" at first versus other headphones, as it splits music apart per intentional or accidental volume differences in the original source.
Most music had much more dynamic range before the Loudness Wars, and it's fine if you like that profile. But it's also a loss of much of the signal.
I'm not an expert on signal, so if I understand correctly what you mean is that instead of using high gain, I should use low gain and more volume?. Although they sound slightly different, when using low gain, the volume pot has to be about 12-2PM ito get my listening levels in latin music and 2-4PM for classic
Yes, correct. You'll have more dynamic range with low gain, lower volume inputs and with the pot turned farther to the right. The best explanation I've found is here:
https://www.reddit.com/r/headphones/comments/7xbzy7/gentlemen_and_ladies_allow_me_to_present_some/
Long story short, the Magni 3 apparently tightly limits input voltage/volume (for electrical safety), and in doing so it compresses or clips the dynamic range. This is not a good thing. I owned a Magni 3 for 13 days and sent it back to Schiit because I hated the compressed sound. I found it hard to avoid compression with my input sources, so it added no value.
Boy!!!!! This is one of these days that I say God bless you all and God bless head-fi!
For all Elex users with a Magni 3, DO READ THIS!!!
If you're a fan of incredibly dynamic, neutral (but natural, as opposed to clinical) headphones with oodles of micro detail, then you'll love the Elex. It's true that the drivers will reveal flaws in poor recordings, and in your music chain. It might cause an outbreak of GAS as you upgrade your upstream gear to match the quality of the headphone, but keep in mind; Elex scales up very well, and would likely be summit-fi for most aficionados. I fell in love with Audio-gd's ladder DACs because the Elex.
In my experience, ALL Schiit amps sound their best on low gain. When high gain is used, they take on a brighter, more up-front character, that is often too much for all but the most laid back sounding headphones.For all Elex users with a Magni 3, DO READ THIS!!!
Long story very short. Try this:
- Set your Magni to low gain.
- Use 100% of volume in your source and find the appropriate volume in the Magni 3. Give it a listen.
- Now set the source to, say 60% and find your desired volume in the Magni 3. Listen and compare. You may iterate until you find the more dynamic sound
I tried this in my office where I have the Magni 3 connected to my PC (don't have a dedicated DAC here, though I'm thinking of getting a Modi) and it provided great results. Dynamics and details did improve a lot, to a comparable level to my home setup (Bifrost + Vali 2/Lyr 2).
I came home to a new Elex and a new Tr-x00 ebony.
Both are impressive.
I have only had amy elex running a couple hours but I did not experience a loss of dynamic range when listening on high vs low on my Magna 3....could be I not getting much dynamic range due to my dac.
