swmtnbiker
Previously known as dpippel
The CTH has no coaxial input, as it's only an amplifier. Are you talking about using coax on your DAC instead of USB to try and isolate the cause of the noise problem?
Yes. My rig is mac pro 2015 - fiio q5 - mcth - ether c flow. At this point, it seems that the direct connection to fiio q5 is cleaner. When I am dialing volume on mcth, audible noise kicks in.
Did Massdrop stop selling this amp with the built in DAC? I swear I saw it a couple of days ago for $319.99 or something like that.
It's there, but maybe hard to find. I typed in the search box " massdrop x cth" and there it was for $249. If you accidentally buy 2, my delivery address is...
Looking at the plate curves I would guess that the amp cannot compensate for just how different the operating points are between the 6922 and 5670. Also the 5670 takes 350mA heater current instead of 330mA. The heater supply can absorb this difference.
You might be able to get this to work, but you might find that the front end cannot operate properly and possibly cause damage.
This is why we recommend only 6922 or equivalents.
Eager to hear how this amp compares to the Schiit Lyr 3
A few days ago I bought a Teddy Pardo 28V power supply for my MCTH which is on its way to me from Israel. I used one of Pardo's 12V units with a dac I used to own and it really opened up the sound a lot, improved focus and a lot of other good stuff. In case you have ever used Naim gear, the Pardo brought about the kind of improvement you get when you upgrade from a Naim built-in power supply to the TOTL Naim outboard power supply. This is the Pardo unit I bought, except it will be a 28V 1.25 amp instead of the 24V 1 amp version that is shown in this link: https://www.teddypardo.com/powersupplies/generic/teddy24.html
Due to censorship, a small part of this review was excised. The full review is available here.
My preferences and equipment history are up-to-date on my Head-Fi profile.
I got the SDAC+MCTH for my office to replace the Dragonfly Red, a particularly musical little thing I've been fond of for several years, which drove my HD6XX to satisfaction for all the work things I have to listen to. At home, I listen with the Sundara, and I have a hole in my chain that has been temporarily filled by the integrated DAC and headphone amplifier in my Audioengine HD3 powered speakers.
I burned in the unit for about as long as Alex recommends. I left MCTH playing overnight and through the next day's work hours.
For my first night listening to the SDAC+MCTH, I used it at home with my Sundara. Long story short, I did not like the pairing of the Sundara with the SDAC+MCTH as much as (to my surprise) with the HD3. After quite a bit of A/B testing between the SDAC>MCTH and the SDAC>HD3, I've come to two conclusions. The Sundara is a can that is inherently slightly airy and soft but just enough to not hurt resolution and clarity. In fact it is the most resolving cans I've heard, and it's this balance of musical clarity that I really like. Paired with the MCTH, overall sound became too soft and too airy, such that it felt a little hazy and resolution, separation, and layering seemed to suffer. It's as if the overall picture became a bit blurry. Soundstage was slightly more expansive, but it did not make up for the worse imaging. More obvious to me, the bass, especially the lower end of it, just did not sound as extended, loud, or controlled through the MCTH as through the HD3, and bass is one of the main reasons I listen to planars.
I decided to take the SDAC+MCTH into my office and pair it with the HD6XX. Maybe I came into this second audition with lower expecations, but I'm very happy with this pairing. The extra airiness that I heard through the Sundara adds to HD6XX's sound stage, and it sounds like the presence and treble is slightly more liquid and smooth. As a consequence of the bigger headstage, sounds aren't as congested and separation seems to have improved. This is a really superb musical pairing and probably the best pairing with the HD6XX I've heard to date.
Overall, I'd say the MCTH is not a particularly transparent amp. It softens and smooths, it's airy and expansive, but it's only ever slightly so. This is all completely subjective so YMMV.
Addendum
FWIW I like my MCTH a lot with the HD6XX, so much so that I've decided this is the end-game for me for this headphone's signal chain. To further qualify how much I like this combination: up to this point in time I've always viewed my HD6XX as the bottom performer in my collection in any snapshot of my collection history. I liked my E-MU Teak better, my HE4XX better, my Noble K10 better, my modded M1060 much better. Most cans I've owned at various points in time were able to give me an overall more enjoyable experience than the HD6XX. But I decided not to sell my HD6XX because it still, in the grand scheme of things, sounds very good, has very well known sound characteristics, and makes for a useful baseline to evaluate new purchases with.
With the MCTH, I'm sitting here thinking maybe the MCTH+HD6XX sounds maybe better than anything I've heard with my Sundara. And I think the Sundara sounds better than anything I mentioned above.
