thefitz
- May 22, 2015
Nope, they have a whole line on their website.Are these only available on massdrop?
You can get them on Amazon and www.digitaldjgear.com. If you email Tal at digitaldjgear he will give you a discount on them, at least he did for me... tal@digitaldjgear.com
https://www.amazon.com/Dekoni-Audio-Fostex-Sheepskin-Replacement/dp/B01N2NXVJJ/ref=sr_1_6?ie=UTF8&qid=1483655291&sr=8-6&keywords=dekoni
https://www.digitaldjgear.com/dekoni-audio-fostex-th900-elite-sheepskin-replacement-memory-foam-ear-pad-set.html
That is definitely not the one specially made for TH-X00. The one for TH-X00 follow the same shape as the default pads (smaller opening for ear) and I guess it is only available on Massdrop.
I have the Dekoni pads (lambskin+memory foam filling) for the TH900, and they of course are suitable to all TH-X00 variants.
They are the best quality pads I've seen for the Fostex headphones, and will likely outlast the originals 3 to 4 times or more (my first original pads on the TH900 worn off after a year, whereas my lambskin Stax 007 pads last about a decade).
The sound is lighter in bass than the original pads (and similar to the more expensive Stax 007 pads).
IMHO they match better with the TH900 sound sig than with the TH-X00.
However, I prefer the sound of my modified TH900 pads (using carbon foam filling) over the Dekoni, at least with the TH900.
I am curious about the match with the TH-X00e, and I will relate about it after I get the ebony.
The inner diameter/opening of the Dekoni pads is smaller than the original pads opening. The Stax 007 opening is larger than the original. However, due to different foam filling, they sound and measure quite similar, except that IME the larger opening will always result in larger sound stage, so it's preferable at least for me.
Thats awesome. Yours are a little lighter than mine. Got mine yesterday. They sound pretty damn good. My only complaint is the cable. Its just bad. Id rather have cheap flexible rubber covered cable than this unweildy thing.
Also agree on the packaging.
But they make great sound and look stellar!
