Mar 3, 2014 at 2:16 PM Post #2,926 of 6,801
  pataburd has already responded to you, but here is my $0.02.  The stock cable is the baseline for me.  I looked for an alternative because it seemed like a pretty simple, inexpensive way to teak the sound and have some fun with the 90's.  It is always good to have a spare cable on hand.  Also, I do not need the 3 button controller as I use this with iPod/Amp.
I tried the Auvio (purchased in store at Radio Shack for $14.99).  The plug body is <0.250" and fits the ML's nicely.  It is only 3 ft length, and for me it is not too practical for portable use.  I take my portable rig (incl. ML 90's) on twice daily dog walks.  I also note a lot of cable noise from the Auvio...microphoincs?   The sound is a very good with this cable, though...maybe a little better than the stock as it seems to reduce some harshness that occur in the HF on some tracks.
I have a DIY cable made from a 3.5 to 3.5 mm extension cable with an ideally sized male (Mikros) end...I cut it to 4 ft and replaced the female end with a RS gold plated male plug.  This cable is definitely a step down from the stock cable.  I am pretty sure that this cable was of dubious quality to begin with.
I have a Pipeline ET-4 and ET-1 also from RS but have not modded the ends of either yet to fit the ML's.
I have a Media Bridge (excellent quality) and Monster 800...neither will fit without mod.  The Media bridge may be tough to mod since the plug bodies are metal.  The Monster is a candidate for grinding / filing / sanding mod.
Thanks for the quick and informative response! I'll keep looking for alternative solutions/cables. It looks like the barrel is the main culprit.
Mar 3, 2014 at 5:33 PM Post #2,927 of 6,801
Mar 3, 2014 at 5:52 PM Post #2,928 of 6,801
^ Da' HYPE is OVA'!!! GO HOME FOLKS!!!
.... cuz it's tyme to HOP ON DAT LOGAN 90s CRUISE BOI!!! Smooth sailing ahead!!!  Dat Titanic LMAO
Mar 3, 2014 at 5:53 PM Post #2,929 of 6,801
I know, i was waiting for like 20 posts, but nope.
Mar 3, 2014 at 6:05 PM Post #2,930 of 6,801
Ok, I posted the below in the Discovery thread, but to stop the tumble weeds around here...
Wow. Correct me if I'm wrong, but this Estas Tonne is a rather amazing guy:
You can also listen or purchase (name your price) the album that has a version of that song on it here:
https://estastonne.bandcamp.com/album/place-of-the-gods
The entire album is beautiful.
Iff you want the reader's digest version, watch from the 12 minute mark of that video.
Mar 3, 2014 at 6:18 PM Post #2,932 of 6,801
I slept with tat thang for 2years..its got bass. I hav forgotten :p
Mar 3, 2014 at 6:54 PM Post #2,934 of 6,801
the beads on his wrists...to hold him down huh. this guy do crazystuff on that guitar.
Mar 3, 2014 at 7:11 PM Post #2,935 of 6,801
Driver #1, step #1: HOLE exposed. Hole cover destroyed. There is no going back now boys!
Mar 3, 2014 at 7:16 PM Post #2,936 of 6,801
now to rip out them wires...and do a thorough job plastering the cup with whatever u hav got.
Mar 3, 2014 at 7:25 PM Post #2,937 of 6,801
  That makes sense.
I foamed directly beneath the hole and may blue-tak the edges before I take out the foam altogether.  There is no sense of "brittleness", the bass sounds warm and full [but lacks thwack], and I am getting a nice enlarged sense of space, but there is a little too much bass "overhang"/boom on some tracks.
What about arranging 4 smaller pieces of felt in a "cross" pattern: at the top/bottom & right/left near cup edges?  Might try that later.
Have to start slicing and dicing that deerskin jacket!
i am not hot on FOAMies ....
anything arranged in a CROSS is gonna attract angels playing harps all day long :P
n demons screaming away...if they are anywhere near.
Let me know, i would be happy to hear your feedback.
Mar 3, 2014 at 7:50 PM Post #2,939 of 6,801
Mar 3, 2014 at 7:53 PM Post #2,940 of 6,801
  I got the ET-4 in today. I think that I prefer stock for some things. It's more moderate on the bass end and has a bit more clarity to my ears.
Is your ET4 really microphonic?  I can't even breathe without hearing noise from the cable.
