It is a couple of times mentioned in this thread, but the popping sounds using USB can be annoying.
I don't mean the relais click in the device itself, but the pops you hear over headphones every time it connects (or locks the signal)?, at the start of a new track or video.
With Spotify it only occurs when you select a track yourself, when you let the album play out itself, meaning when you let a song finish and just wait for the following track to play there will be no pop, it is only when selecting a song yourself this pop occurs. With Youtube however there are instances in longer videos that this connection/lock pop occurs frequently in a video. The same with Netflix. Not always, but it just shouldn't happen at all in my opinion.
I have set under advanced sound settings in Windows the sample rate and bit depth fixed at 48K/32 bits (unchecked the exclusive mode) hoping this would fix these pops, reasoning that the DAC may reconnect and lock because of different sample rates in a particular video? To no avail.
Fortunately it is only a luxury problem I can just use my Audio GD for the USB media and the Marantz for the coaxial connection with one of my CD players...but still, it doesn't sit well with me
