oqpi
- Apr 9, 2015
That is correct Jay... I experienced it fully....
What happened... I am an audiophile for over 40 years.. owning multiple audio systems.. but at the moment they are all far away, as we moved to Southern California two years ago..
And i had only my Grado headphones to get some of my music from a laptop...
Finally we decided to get an audio system... and started reading reviews online.. then going to some stores in LA area... and we were surprised to hear such a bad sound from 10-20-30K dollar system (!!?).. what to do..??
I decided to go on a path.. which I recommend to anyone who is on a limited budget for audio... get a good mids-highs sounding speakers (bookshelves could be nice, but still floor stands are better).. then get a good integrated amp WITH SUBWOOFER OUTPUT... that is key... why?.. because the small speakers with small drives cannot reproduce high fidelity bass sound... no way... impossible... cannot be against the laws of physics...
so, i've got a pair of Monitor Audio RX6... with an Outlaw RR2155 Receiver and THE Ultra-X12 sub.... the Outlaw receiver has a great crossover for the sub feed... (100Hz-80Hz-60Hz setup) and this makes a $2400 US system to sound like a 50k USD system, or better... why??... because there is actually 2 amplifiers working there.. the receiver's and the sub's... and 70% of the power always is taken by the woofers.. anywhere.. in any audio.... and for that you need bi-amping and that kinds... with eventuallly monoblocks.. get the idea how much money would that cost ???
and i solved it with under $2500 US...
BUT... you are right about the laptop USB as a source... it is unbelievable noisy, crappy... all messed up sounding... chopping the music, like in a meat grinder....
honestly... after all my gear arrived, I was depressed with the sound !!... from the laptop... i didn't have a CD player in the home yet....
and I started to read about external DACs and stuff... thinking that maybe Outlaw's internal DAC is not too good... BIG MISTAKE !!....
luckily, I've got in touch with the people from Schiit Audio.... and they (Nick T) explained to me how noisy USB ports can get.. and how hard it is to keep the power constant in a USB port.. etc...
so, instead of recommending me their $500 DAC... Nick told me what the little cute WYRD does... it actually cleans and stabilizes the USB power to a perfect 5.0 VDC value... and that will allow the digital signal to travel nicely from the PC USB port to whatever DAC you have.... WOWWWWW !!!!
so i got the WYRD box ordered... and wouldn't believe what happened..!?..
(in the meantime i also odered the Onkyo C-7030 CD player too... came at the same time)
I could compare.... CD played by CD player.. and the WAV file (uncompressed) played by the laptop...
two different sources, two different paths.. same music... same time in parallel, switching from "USB" to "CD".. on the reciever...
AND I COULD NOT FEEL ANY DIFFERENCE WHATSOEVER !!!!!!... NONE!!.... NADA !!!... AND BOTH SOUND GREAT !!!!!!!!!!!!
the detail, soundstage.. dynamics and frequency range are better than what i've heard in the stores with Rotel, or MacIntosh amps and Martin Logan, or B&W speakers, costing 20-30 times more !!.. if you dont believe me, come and listen... honestly....
And again.... you are right.. USB needs a WYRD inserted in between the PC and the DAC.... no question.... you will be amazed...
And also... some good under $1,500/ pair speakers need a receiver with Subwoofer output and a powered sub woofer......... and you will be thrilled !!!!!
Here is my system:....
https://picasaweb.google.com/109243130858369011279/BestAudioSystemThatHonestMoneyCanBuy?authuser=0&feat=directlink
