Thanks Afrikane. I think all the HD250SE owners owe our amps to your prototype
I'm really surprised by the HD250SE's synergy with the K1000. It drives the K1000 very well... even better than the Gryphon Audio Tabu Integrated Amp which I had the pleasure of auditioning 3 days before my HD250SE arrived.
I like the amp so much that I've ordered a matched pair of BRIMAR CV4035 - MINT NOS 1960 Military Box Plate Premium Grade driver tubes. Will let you guys know how I like them.
Sound aside, I've a small hum issue which I want to check with you other HD250SE owners.
With a Grado RS-1 plugged into either of the jacks, here's a description of my hum "problem":-
1. With all the inputs disconnected, the hum is very low (almost imperceptible). It does not get louder with the volume turned up.
2. As soon as I plug a source into the inputs (it's the same for both inputs), the hum is audible and it gets louder when I increase the volume. At first, I thought that it could be my CD player (Marantz SA8003). But then I plugged in my friend's Audio Research CD-5 player into the amp and the hum is there with the same intensity. Changing interconnects didn't help. I used my ipod with another interconnect and I got the same hum. Plug out all the inputs and the hum almost disappears (see point 1).
3. There's also a hum when the input switch is turned to the "M" or mute position (which increases when the volume's turned up) but it's of a different frequency/tone to the hum described in point 2 above.
The good Dr Peppard replied me as follows:-
1. It's not the tubes
2. There's a slight hum with the input switch at mute due to the way the grounds are wired to the switch
3. He's unable to give a definitive answer regarding the hum
Can I just ask if you guys have a similar hum "problem"?
To be honest, the hum is very low at listening volumes and doesn't bother me (except when listening to classical music with very quiet passages). It's something that I can live with, but of course I'd like to eradicate it if it's practicable. I don't mind if it's a design characteristic since the amp has exactly the sound signature that I'm looking for - I just don't want to have a "bum" unit.
Also, when your amps are nice and hot, do you feel a slight vibration when you place your hand on the transformer?
Thanks guys.
