Monday, March 3
A. OK received the triple.fi 10s today.
B. Had them for 45 minutes.
C. They are being returned on Tuesday
OK what happened between Steps B and C?? I will tell you:
Steps to the return of my Triple.fis
B1. Tried to put those big bad.mamma.jammas into my ear
B2. No seal. No way.
B3. Tried the other plugs - big plugs, small plugs, no plugs... mixed plugs.
- Calm down. These things take time. Sooner or later it will work. Just follow the instructions. You read them over and over before the headphones came and even now.
- Funny: Even with no plug it seemed too big for my ears.
- Maybe I am trying too hard?
- I probably have big ears but a small brain and just cannot follow instructions [even video ones] to get the results I need.
B4. Getting a little better-- OK let's listen to some music
Thoughts at this point>>
- I do not think I have a good seal. Test: With the music off I can hear everything and everyone. Only my voice is muffled.
- O well at some point I cannot wait 30 minutes trying this out.
- So I turn the iPod on for a quick test. Here comes the music!!
B4.1 Sounds good. Lively, music separation. A sense of power and wealth:weight in the music. This is promising. Very promising.
B4.2 Hold on. I must
not have a good seal because once the vocals start they sound hollow but not recessed (as other reviewers have mentioned) -- the vocals sound like mono whereas everything else is in stereo. The bass is a bit less tight than expected.
B4.3 I am sure it is the seal. Test: To pull them out you are never supposed to just pull them out. I pull gently just a bit. They fall out easily.
- I have bad ears and cannot follow the simplest of instructions
- And my ears hurt!! (Just to help anyone reading this -- understand my inability to tolerate discomfort)
- My feet hurt when I walk
- My face hurts when I wash it.
- My brain hurts when I think.
- My fingers hurt when I type.
- I am over-sensitive to pain-- so much so I ignore most of the pain because I know I am a little boy when it comes to discomfort. So if I ignore myself I get over it.
- Note to ponder: After a while Grados did not hurt but felt pretty fine. All I had to do was ignore the initial discomfort.
Back at the ranch...
So I want to keep trying so I pull a little here and there and then something goes wrong. One of the sides (Right) no longer plays music. I fell a bit culpable but it could not have been
all my fault.
- The triple.fis feel like high quality so this is not a reflection of UE but an user error I am sure.
- I try a couple of things but to no avail. Without really wanting to troubleshoot or try further given the seal thing-- I just say to my wife flatly, "They're going back."
- but I set up for the big thing, "But you know it looks like I need custom earphones and they cost sooooo much more."
- I think she's OK with it. Or just ignoring me.
Needless to say they must be returned to Amazon.
-- End of experiment... for now.
-- To date I have had problems getting a seal with the Klipsch Custom 3s and the UE Triple.fis. So ----- this is an user error not a Klipsch or UE issue. However the Klipsch IMAGEs fit in fine -- no issues and mega-comfortable. I could only complain a little about the discomfort of course because I am a little boy when it comes to pain.
I really liked the Klipsch IMAGEs but returned them because they were quintessential good Head-fi products. So good then made me want to upgrade.
I wanted all of the Klipsch:
- comfort
- bass
- fun factor while listening to music
- easy listening
While gaining
- better instrument separation and better resolution in general
- higher highs
- improved soundstage
I was greedy and UE has made it clear to me. You want fame well here's where you start paying for it! In sweating the decision to get UE11.
There is a possibility to get another pair and then put on Averysound custom tips but I am thinking why bother??
So I certain I might just do it and definitely I will come close to pushing the buy button on the UE11s. I am 100% confident I will with 80% certainly consider buying the UE11s and there is a 50/50 chance I will pull the trigger as soon as tomorrow or certainly further research other custom phones.
I called an audiologist and explained what I wanted. She responded, "Have you heard the Sensaphonics. We do impressions and the whole gambit for those earphones all the time."
"Yes I have heard of them. They, um, seem like a great earphone but... I have heard, no reflection on you, but that they have some reliability concerns. I don't know perhaps I heard wrong. I will check them out too."
O - well.
That's my update.
Does anyone have the 2X-S and the UE11s? Care to comment? I know Jason had the 2X-S at one point.
