thanks! I'll see how I can work that out I guess.
Using the Mimby to KEFs directly would mean that my Magni3 (and thus headphones) would have no access to the Mimby - there's only one pre-out on the Mimby
You don't need to do that if your speakers have volume control. I was running into the same issue and i just turned the volume down on the speakers to half way. Now, even if I use high gain of the M3 there is no distortion. Hope this helps.
