preproman
- Mar 16, 2011
Why the dislike for that Schiit? I'm not a fan of the case work. However, they seem to be putting out some really good Schiit.
Oh and the case work I think is the best thing about Schiit products (together with the name).
Don't they also use a plain casing method to lower costs?
I think so. The case looks pretty much like a standard "U" shape. The design may have a lower cost, and also when it comes to assembly, I'm sure some time is reduced on that aspect, too. Please keep in mind that my observations and comments are not meant as criticism of Schiit. I'm actually quite impressed of their offerings that are truly "made in the U.S.A." - and, for the price points they offer their gear at. I'm sure someday, I'll own their gear.
Saw these on fb from Moon Audio and shot Drew an email, he let me know he can do it but Dan would need to provide new stickers to cover the hole. I'm def considering it strongly.
Paradoxper, I just noticed your avatar..how do you like the Lyr with the Mad Dogs? What tubes are you using?
Every T50 clicks when the cup is moved and it's not on the head, that's just the plastic joint. None "grind" unless there's dirt or a contaminant in the joint. The degree of clicking and motion varies a bit as it's not a close tolerance ball joint.
As this doesn't impact playback it's up to you if you want to return it. If you do, no worries, I'll clean the joint. I will be on vacation from the 11th-18th. In my absence we'll be shipping, but I won't be doing any warranty work that week.
[size=medium]I hear these sounds almost 80% of LCD2, been 75% cheaper….I want to know how much they scale with D2K sub bass….also I wish Mad Dog would have priced these little more cheaper say 180$...I was considering to get either Mad Dog T50RP or HE400, as difference only around 150$ I would go with HE400 itself…I read on many threads that HE400 beats D2K by a big margine[/size]
