One thing I want to say right up front here is that everything above should be taken with a grain of salt since I did all my review testing after only 14 hours of break-in (well, closer to 20 by the time I was done, but still). I know for a fact that some headphones sound significantly different after a week or so (even a few weeks).
I have had the Labtecs plugged into the second jack on my Max non-stop with the CDP on repeat, so they'll be "breaking in" consistently over the next week or so. I will definitely be revisiting them to make sure that my initial comments were accurate. If it turns out that after break-in they are much better, I will edit my review accordingly.
JoeBloggs wrote:
Hey, is there a way you can really check if these are closed headphones? |
I actually considered taking them apart, but wasn't prepared to possibly break them yet
I think that dkswong is correct -- a lot of sound escapes through whatever that black material is behind the grill, so after further testing I think they should definitely be classified as "open."
I have a pair of KSC35 which cost AU$80 (US$40). This may be "cheap" to headwizers/fiers but it's by no means "cheap" to the ordinary person who's used to <US$10 phones...
Yet I would definitely recommend them as the minimum entry level into the world of "real music with headphones"
Can you say that about the Labtec Elite 840's? |
I completely agree with you about the KSC-35 -- I think they are fabulous headphones for the price. At this point, if I had to recommend inexpensive headphones, I would stick with my previous recommendations of the Koss Porta/KSC line, the Sennheiser MX-500, and the Koss UR20/30. White the Labtecs are definitely better than most of the headphones that come stock with portable equipment, and are better than most headphones for $20, they still aren't as good as those above (I wasn't able to compare them to the UR series, but given their reputation I feel I can recommend them in good conscience).
dkswong wrote:
Juts give them some more time. I don't see any prominent problem with the treble and bass now. They have stretched considerably after my using them for more than a few weeks. |
I am very willing to do that; as I mentioned above, many headphones do break-in, in my experience.
I don't mean to start a fight here, but I think my system while not perfect, should not have any major flaw or weakness in the chain. I am using Marantz CD player connected the the X-DAC, and the X-DAC connected the the X-cans. |
I don't think that's "fighting" material
However, I would disagree with you in that while the X-CAN is a very good amp that give the HD580 some great midrange, its weaknesses in driving the HD580 (relative to better amps) are in the bass and in detail. Given this, I think it could be logically argued that when comparing the 580 and 840 using the X-CAN, you wouldn't hear as much difference in the bass and details as someone using a Max.
