amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
Don't start replacing anything just yet. The symptom sounds like some MOSFETs are simply over-biased and passing too much current.
With the power off, first try turning the BIAS trimpots of all channels to the fully-counterclockwise position and the BIASOP trimpots to the middle of their travel, remove the L/R channel opamps, then re-do the initial setup procedure found on the M³ website. See if that is successful.
Originally Posted by phobus I was re-wiring my M3, and put everything back together, but now... With the Ground opamp out, the voltages measure fine. Once I put the opamp in, the voltage between pins 4 and 7 read 6.5 volts, and the power supply gets REALLY hot (its not the opamp, I tried other ones).... This doesn't happen with the L/R opamps so I'm guessing I blew something out in the ground channel. Is there anything to check for, or should I start replacing components? Thanks |
