amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
The input impedance of the VU meter should be very high or you'd be introducing an undesirable load at that point in the circuit. If the meter is passive (i.e., containing nothing more than rectifier diodes and the meter coil itself) then it would definitely not be suitable. A separately amp'ed meter drive circuit would be ok, but be aware that the node just after the volume pot in is the most sensitive point in the amp (to noise interference and stereo crosstalk), so be very carefully about adding extra wiring or components there.
Originally Posted by skyskraper ok it was late and id had a long day. run it before the amp section but run it from the output of the pot. |
