skyskraper
- Aug 5, 2004
i found a gain of 7.5 to be just short of what i need. a gain of 11 should be fine
Originally Posted by CPL593H What should I set the gain at on the M3 I'm building. I'll be using a home system CD source like my NAD502 or a Sony SACD player. The phones will be Sennheiser HD600s. Should I use the default gain of 11 or back off some? thanks |
Originally Posted by CPL593H What should I set the gain at on the M3 I'm building. |
Originally Posted by Jaypetermen How do you adjust or set the gain to 11 on this amp? |
Originally Posted by DigiPete from Amb's website on the M³: |
Originally Posted by amb See my M³ site (under Parts list) for a list of tested opamps. The OPA604 is among them. I do not recommend using the AD797 here because it is not FET-input and has high input bias current. In the M³ there are no coupling capacitors, so the output DC offset voltage will be high, and will vary with the volume control setting. |
Originally Posted by steinchen opa604 ... hm ... power supply voltage up to +-25V |
how does this opamp sound ? Can anybody give a short discription of its sonical character ? |
where is the voltage limit of the M³ ? Caps 63V (electrolytic), tle2426 40V, opa604 50V, 2n3904 40V -> with a little safety margin of 2 or 3 Volts -> 38V max ? |
Originally Posted by Ob3ron Would connecting the pot's ground screw to the input ground suffice since input ground will be connected to the case via the input jacks? |
Can I just put it inline with the AC live wire (one side going to the middle prong, the other going to the top or bottom)? |
c) I'm making a dual input MMM and I've got a DPDT switch for input selection. I read in some thread (can't seem to find it now), that in theory it's not the best idea to have my two sources' grounds connected as are by using a DPDT, but practically, I shouldn't have any problems. Is this correct? |
