tgx78
Member of the Trade: tgxear
No smoothing! REW uses sine sweeps which helps a lot with keeping things clean. You're using audiotools right? A few things to note for that. One is make sure your mic and soundcard are calibrated and the calibration compensation file is selected in audiotools. Second is that you might want to try averaging for longer time, crin does about 30s to a minute, which I agree with, for a quicker measurement 15-20s can suffice but longer is better. Also while averaging make sure the surface the mic is resting on is stable and nothing's inducing vibrations. Hope this helps!
thanks! I do aim for about 40-60s and all calibrated and compensation files are loaded. Even though I tried my best, I think I might not be getting 100% air tight seal on my couplers. Also running pink noise is not the most ideal compared to the sine wave sweeps.
edit: will check on surface vibrations
