- Aug 10, 2010
Mike did a review of the LZ A6. Apart from some treble issues he quite liked it.
https://headfonics.com/2019/01/lz-a6-review/
Where did you buy your A5s?I had a driver failure in my LZ A5. I lost my proof of purchase so I couldn't claim warranty. Contacted LZ and explained the situation and they sent me a new set. Very good service. Thank you.
I'm not sure, but they didn't ask.I wonder if the vendor for Bubblejuice was authorized by LZ? If they were not, that would be grounds for no service from most manufacturers. My first Shanling unit was purchased on Amazon from an unauthorized vendor and Shanling would not support the unit; they had me go to the vendor.
Folks - I have the A5 and find that the treble, no matter which of the included filters I use, is too much for me. Would it be worth buying the much more extensive A6 filter set? Do any of those filters tame the A5 treble?
Any insights as to whether the A6 fit, and if they do if they tame the treble?The A4 filters doesn't fit but I preferred mine with the SEMKARCH CNT1 filters as they softened the treble to my liking. I don't know if they're available separately though....
OK, thanks! The filters are $45 on Penon and I don't want to throw more money at this if the filters aren't going to bring the A5's closer in line with what I am looking for.I'm pretty sure I've read that the A6 fit but haven't tried myself so ymyou should double check with a knowledgeable seller like Penon or similar.
Unfortunately I've never heard the A6 so I don't know nothing about its filters.
Thank you - there is hope still for my A5...!A6 filters fit A5 for sure, I have both IEMs and indeed all the A5 filters are too bright. Comply tips and a copper cable helps to reduce brightness.
Haven't tried A6 filters in A5 yet but will do.
