LZ A5
post-14945901
Post #1,171 of 1,177
jsmiller58
Isolated
Isolated
I bought the A6 filters from Penon Audio for use with my A5. As you all know, we all hear differently, so i can only tell you "MY" opinion. I never had trouble with A5 treble, but with some of the A6 filters it definitely cuts down the treble. So far the pink filter works best for me by leaving enough treble without hindering the bass.
Thanks!
post-15130818
Post #1,173 of 1,177
shampoosuicide
Comparison of the LZ A5 and Campfire Andromeda below:
Spotify Extreme on iPhone > iFi Micro Black Label (IEMatch off) > Andromeda vs LZ A5 (pink A6 filter)
Tonal balance — Andromeda is relatively warm and full-bodied, with a much more forward midrange, and distinctly less treble emphasis. I would describe them as romantic (though by no means ‘tubey’) and involving. In turn, the A5’s are U- to V-shaped, airy, and relatively dry and lean (though by no means unexciting).
Bass — Andromeda’s bass is rounder and less impactful/punchy. A5 is tighter, tauter, and more solid.
Separation — Equal.
Soundstage — Slightly taller soundstage on Andromeda. Width and depth are similar. Larger images on Andromeda. A5 has smaller images but a greater sense of space between images.
Imaging — Andromeda has a somewhat more holographic, three-dimensional sense of placement.
Clarity and detail — Clarity, resolution, and transparency are distinctly superior on A5. The Andromeda just sounds less clean and clear in comparison.
It seems almost heretical to say this, but I would put the A5 ahead of the Andromeda in terms of technical ability, at least in terms of sheer resolution. If you prefer a U- or V-shaped sound signature and like a drier/leaner tonality, the A5 is the clear choice. If you’re willing to sacrifice absolute clarity and detail for a more palatable, musical tonality, and a more forward midrange, then the Andromeda might be a better fit.
One last note for prospective A5 owners: skip the ‘new’ A5 filters, and pay the extra $25 for the set of 8 A6 filters from Penon Audio. The purple filter will bring the treble down in line to very listenable levels, and in line with the rest of the spectrum, while retaining the airiness and extension that characterise the A5’s signature.
post-15130935
Post #1,174 of 1,177
expatriot
Cebu, Philippines
Cebu, Philippines
shampoosuicide: I disagree with you, To "My" ears the A6 purple filters are way too bassy and take away most of the detail retrieval of the treble. I think the dark grey filters offer the best compromise of treble and bass.
post-15132263
Post #1,175 of 1,177
shampoosuicide
Sure. I think that depends very much on the tips and cable used. With the FiiO LC-3.5D silver cable and Acoustune AET07 tips, I still hear excellent treble detail and extension and well-controlled bass with the purple filters. To be sure, the pink filter (which are also the ones I used for the comparison above) still performs better than the purple in treble detail/extension. I found the silver filters to sound rather unnatural with my setup.
post-15132299
Post #1,177 of 1,177
shampoosuicide
