chef8489
- Jul 1, 2005
Middle finger is always at Duke.I'll add my middle finger towards Duke, and we'll be in stereo.
But I'll also have to change my login name to TarHeelsare1.
May i ask what’s the general sound coming from the lyr3 and/or it’s two dac options
I’m looking for an amp that will play very nicely with an elear, work well with the he x edition (i’m worried it may be TOO laid back as an option) and could well work with an lcd 2 too
I’ve also considered the cayin iha6 and buraon virtuoso v2+
Detail does not have to be exceptional but good. My main setup is a woo wa2 for my hd800 and lcd2
And I’m not aure which way to go for my elear amd potentially the he x
Thanks
Kinda defeats the purpose in the Lyr 3 thread lol.Can't comment on the lyr3 combo but the iha6 is a great combo with the lcd2
But it helps me for startersKinda defeats the purpose in the Lyr 3 thread lol.
Was that with the lcd2c or different cans? Did you try different tubes? Could have been a faulty tube.You are correct. I'll stay on topic. After trying both the lyr3 and iha6 I decided on the cayin. Like I've mentioned before I was hearing a weird disconnect between the timbre of the upper mids/treble and the lower mids/bass.
It's a solid unit just not for me.
Thanks
That’s great info( with TungSol 6SN7 and Amp only)
Neutral-warm in tone and generally a touch laidback. Doesn’t have a bloomy or a syrupy character, like that of a pure tube amp as it has very good clarity. Nor is it dry like a neutral SS amp. Not the most hardest hitting in the bass. Amazingly linear treble, free from hardness or glare (although, if your DAC is too bright, some of the brightness is going to come through). Good staging capabilities to support 800’s stage. But could use some depth and air for better layering and separation. Resolution is quite good. I guess to the level of what you could expect from a $500 amp.
I run my Lyr 3 + new TS with a NOS DAC (Holo Spring KTE 3), I don't think this setup is "laid back," at least with my main headphones, MrSpeakers Ether C Flow. Somewhat more liquid sound than with other amps I've used with the same DAC (Jot, Neurochrome HP-1), but crisp transients and solid bass are still there. At least with the music I listen to, mainly modern jazz, modern classical, world.I’m thinking it MAY be a little too laid back for what I my looking for - already have a metrum hex nos dac so may be overkill in that regard, particularly with the hifiman ed x I’m considering. Unless the lyr multibit dac counteracts that ......maybe
That’s great info
