Luxury & Precision (LP) W4, Successor to Their Popular W1/W2 USB Dongle is Here!
Jul 13, 2023 at 10:25 AM Post #917 of 1,433
Hi All. I just received W4. Great little device. Can someone let met know what the UAC 1 or UAC 2 setting does? Maybe overlooked it here.’… Thanks :)
Jul 13, 2023 at 10:28 AM Post #918 of 1,433
UAC1 is used on older devices like the Nintendo Switch, so unless necessary, 2 is the way to go. It's mainly an issue compatibility - wise :)
Jul 13, 2023 at 10:44 AM Post #919 of 1,433
Thank you very much for this information :) 2 it is….
Jul 13, 2023 at 5:49 PM Post #920 of 1,433
Check this out.
New full protective case.
The case finally made it here.
Good quality, snug fit, definitely not magnetic. Green is actually dark green, darker than W2 case, both are pictured below for comparison.
Jul 14, 2023 at 6:17 PM Post #922 of 1,433
Thinking of selling my W4… I love it, but to be honest I hardly ever use it (either using my daps or TWS these days)… if you’re in the EU and are looking for one, hit me up. Will work on photos and an ad this weekend!
Jul 15, 2023 at 5:47 PM Post #923 of 1,433
For what it is worth, Parallels has never worked for me when it comes to updating firmware on dongle DACs, whether from L&P, Fiio, or other manufacturers. I think this is a shortcoming of Parallels on Mac OS itself, not an issue on L&P's side.
No problem at all with the free version of VMware Fusion (player version 12), just updated without problem (Intel MacBookPro)
Jul 15, 2023 at 8:04 PM Post #924 of 1,433
Hi guys!
I've tried to do burn in with the W4 without the leather case but after a few hours playing some music via PC the W4 was getting extremely hot and there was only a hissing noise instead of the tracks I've tried to play. After cooling down the W4 is now getting hot after two tracks...I don't want do bake beans with this dongle...its so disappointing...
Has anyone the same problem?
Thx
Jul 15, 2023 at 8:42 PM Post #925 of 1,433
Hi guys!
Thx
Please define 'extremely hot' - Like warm to the touch kinda hot, almost burning your hand hot, or boiling water hot? If it is the former, I'll say it is relatively normal, if it is the latter two then obviously something is wrong. I don't really purposely burn in my W4, but even after an hour or so of listening, I'll say it is barely lukewarm at most.
Jul 16, 2023 at 1:01 AM Post #926 of 1,433
Guess too high of a gain with hard to drive headphones can push them. It does get warm after an hour with Monarch MKII (relatively hard to drive IEMs), but nothing that I'd personally describe as "extremely hot".
Hissing though is a real concern, may be you baked it, check with the retailer.
Jul 16, 2023 at 5:15 AM Post #929 of 1,433
Just checked with my thermal camera - after about 10~15 minutes of playing 1 kHz pure tone on my PC to a 47 ohm dummy load via balanced out, my W4 (inside leather case, not exposed to any direct cooling) went up to 37~38 degree Celsius from ambient 30 degree Celsius room temperature. From past experiences, it might get a few degrees hotter but never going to be anything more noticeable than that.
Replacement aside, I'll also check the PC USB port's power just to be 100% sure.
Jul 16, 2023 at 8:20 AM Post #930 of 1,433
... and maybe try a different usb cable as well?
