docaditya
- Jul 3, 2016
Forgive me for asking such a noob question. Can Lotoo Paw S1 be connected to any external amp through 4.4mm balanced port ?
Yes you can but external amp should have balanced XLR port. And keep the volume of s1 to max. Offcourse this way your phone may be overloaded.Forgive me for asking such a noob question. Can Lotoo Paw S1 be connected to any external amp through 4.4mm balanced port ?
Thats a great addition.It's not a true LO, they don't even specify it as a pseudo LO, only PO. But regardless, yes, you can connect it to external amp. Coincidentally, S2 spec lists Line Out output voltage for both 3.5mm and 4.4mm outputs.
@HuoYuanJia
Re. “Dental” filter, i finally asked about it on a chinese forum, turns out, sibilance is called “teeth sounds” in Chinese, and that filter acts as sibilance control for upper mid forward iems.
A little late but now it all makes sense…
I don't use the presets on my S1 or L&P W1. Incoming audiophile heretical statement: I want my earphones/headphones to sound how they were designed to sound. If I have to use EQ then I have the wrong earphone/headphone. Speakers and room acoustics are a totally different animal.I always wondered about this. Frankly, I find the presets way too strong for my taste, the only one I sometimes use is Headphone.
Depends on your age, wait a few years and you might be thankful for EQ. Trust me, I was in the same attitude.I don't use the presets on my S1 or L&P W1. Incoming audiophile heretical statement: I want my earphones/headphones to sound how they were designed to sound. If I have to use EQ then I have the wrong earphone/headphone. Speakers and room acoustics are a totally different animal.
It amuses me that people think they hear anything the way it was “designed”…. As if any of us have reference hearing, or the designers of gear or producers of music hear things precisely the way others do . Ah…, to be innocent again….Depends on your age, wait a few years and you might be thankful for EQ. Trust me, I was in the same attitude.
Was this directed at me as I referenced "designed"? If so, then read spoiler,It amuses me that people think they hear anything the way it was “designed”…. As if any of us have reference hearing, or the designers of gear or producers of music hear things precisely the way others do . Ah…, to be innocent again….
Was this directed at me as I referenced "designed"? If so, then read spoiler,. If not directed at me, just ignore.I pick IEMs for tuning as one important element of an IEM's sonics. EQing changes the tuning. If I don't like how an IEM sounds (is tuned), I look elsewhere.I don't see the need to change EQ as I change between a number of IEMs.
Hi folks. I've just got my S1, has anyone managed to use it with Tidal's new Android audio bypass feature yet? The app prompts me to allow the DAC when I connect it, but when streaming a master quality track the S1s display indicates "NONE" where I would expect to see "4 x MQA". There's no issue with sound distortion or anything though. It works as expected through UAPP.
