- Oct 6, 2013
You should talk to these guys.
Already did, Mim! They gave me the same answer as Shuon above
Do you have any new impressions? How is the EQ? And did you try the upsampling and do you hear any difference?Second batch of LPGT have been shipped to buyers. Also LPGT attended some head gear exhibition in HK last weekend
I've listened to the LPGT for a day. My impression is that SQ wise it is in the same league as the WM1Z and SP1000 (not on Hugo 2's level yet).
Sound signature-wise, it reminds me of the SE100, with better treble extension.
LPGT is the most neutral and tonally balanced sounding player among LPGT, WM1Z and SP1000. Compared to LPGT, WM1Z has boomy bass and is more colored across the frequencies; the SP1000's midrange sounds more hollow and the treble is hotter.
Personally I prefer the tonality of the LPGT and the overall sound-signature of the WM1Z. Might switch to LPGT because of the fast card-reading and the search bar.
Any idea how lpgt compare with lpg in terms of sonic quality? Is it worth switching from lpg to lpgt or are they are just different?
I was going to move to r2r 2000 but hifiman declared they will end the standalone dap feature via future firmware update making
it a mobile streaming device and usb dac only.
I've heard the SP1000 both ss and cu running the latest fw. I am pretty sure it is the most treble-heavy among the three. I'm talking 10+kHz treble, the sounds of hi-hat, symbol, etc. SP1000 also has a dip in its mid-bass, making the midrange percevingly clearer and overall more v-shape.Are you talking about SP1000 SS? Which FW version? The latest (from April) fw1.08 turns SP1000-SS treble silky smooth. Between SP1000SS, LPG, WM1Z, and DX200/amp8 - SS actually has the smoothest treble. SS with early fw1.06 had a hot treble...
Like I said, Hugo 2 is on an other level compared to these totl daps imo. It simply images better and has better soundstage depth. More "correct". Sound signature-wise it makes sense to compare WM1Z and LPGT to Hugo 2. SP1000 has a complete different tuning.Thanks for your feedback. Between the LPGT and the Hugo 2, which would you say has a fuller mid-range and a smoother treble.
