I'm still debating which Lotoo DAP is going with me on our next ten days trip. Paw 6000 or the LPGT Ti. The P6K is lighter but the sound doesn't come close to the Ti. I'd be devastated if I damaged or lost the Ti during the trip.
Lotoo PAW Gold Touch - Touchscreen, 4.4mm Bal, USB DAC, Bluetooth
- Thread starter EagleWings
- Tags
- lotoo lotoo paw gold
I agree, my LPGT Ti stays home and as much as I would like to carry it around, can't bear the risk of damaging/loosing it while doing so. Even my IEMs. Outside my home means falling back to TWS sadly. Not so bad still and it always makes me happy I have a DAP and IEMs to go back to afterwards.I'm still debating which Lotoo DAP is going with me on our next ten days trip. Paw 6000 or the LPGT Ti. The P6K is lighter but the sound doesn't come close to the Ti. I'd be devastated if I damaged or lost the Ti during the trip.
I think the fact that Ti is not only expensive but also a limited run, which seems to have now come to an end, makes the prospect of taking it out and potentially damaging it in any capacity makes the prospect all the more undesirable. Once it's gone, it's gone.I agree, my LPGT Ti stays home and as much as I would like to carry it around, can't bear the risk of damaging/loosing it while doing so. Even my IEMs. Outside my home means falling back to TWS sadly. Not so bad still and it always makes me happy I have a DAP and IEMs to go back to afterwards.
Hello all, for anyone interested I heard back from Lotoo about this. Seems like it might be related to a particular kind of 4.4mm IC. I quote:Here's a question for LPGT users with amps: I find on my Ti, there's quite the difference in terms or connecting from SE vs balanced when connecting to an amp. Namely; SE seems to have higher output and sound somehow more "robust." Note, this is LO which in theory should be equal in terms of output. It may well be an idiosyncrasy of the amp I'm using (Mass Kobo) but if anyone else has observations of SE/balanced LO, I'd be delighted to hear.
Hello there. According to our inquiry with the RD team, if the SE and balanced outputs are the same in PO mode, it indicates that the DAP itself is functioning properly. The RD team speculates that the issue may be with the 4.4 conversion balance cable. If the wiring sequence is incorrect, it could result in a voltage reduction, where 2V becomes only around 1.2V.
This could well be the case because I was mostly using Brise Audio interconnects designed for Mass Kobo amps. However, I did also try Plussound and ifI and had similar results. Curious to know, therefore, which 4.4mm IC Touch users are using....?
If anyone in Europe is looking for a LPGT Ti, hit me up.
I have to part with mine!
Amadeo Nospherathu
Can't answer that question, I haven't purposefully compared 3.5 and 4.4 specifically in line output mode.You're no doubt right, but does this explain why SE LO seems to produce a higher output than balanced even when they're both set to 2V?
It's OK, I received an answer from Lotoo - quoted above. It's likely due to the wiring of an IC cable.Can't answer that question, I haven't purposefully compared 3.5 and 4.4 specifically in line output mode.
Amadeo Nospherathu
I don't think Lotoo's interface is bad. It works well, it is stable, and despite its minimalism, it has its own recognizable and convenient design.Of course, no streaming, no touch, clunky UI - but really not that much of an issue. Its success as a player depends on how well your files are organised. Once that's in place, it's fairly effortless. Plus, despite being 2017 old, the 2017 scans a 1TB card in just a few minutes.
Yes, just note I'm describing Lotoo Paw Gold 2017 here rather than Touch. I'm a huge fan myself and take immense pleasure in the VU metre reading. I'm just saying, from the perspective of today's DAP world, with the focus on a smartphone like presentation, it's not for everyone.I don't think Lotoo's interface is bad. It works well, it is stable, and despite its minimalism, it has its own recognizable and convenient design.
Amadeo Nospherathu
I have comfortably and long used LPGT for portable use. In transport, or even in a pocket for cycling in the park - quite convenient. Feels a little in the pocket, but does not weigh.Nothing to do with portability - perfectly pocketable. Just not terribly at ease sipping my café noisette while completing the morning's crossword and simultaneously ensuring the Ti is free of grime, dust, croissant flakes, and other pollutants, human or otherwise
Others in the Lotoo Ti camp might be braver than I
Amadeo Nospherathu
Therefore, in such cases, I will keep the player in my pocket.I'm still debating which Lotoo DAP is going with me on our next ten days trip. Paw 6000 or the LPGT Ti. The P6K is lighter but the sound doesn't come close to the Ti. I'd be devastated if I damaged or lost the Ti during the trip.
Amadeo Nospherathu
I don't think Gold 2017 will feel any better if you spill something on it either)I'm sticking with Paw Gold 2017 (dread the thought of a juice spillage on the Ti!)
Truth!I don't think Gold 2017 will feel any better if you spill something on it either)
