Lotoo PAW Gold Touch - Touchscreen, 4.4mm Bal, USB DAC, Bluetooth
May 11, 2023 at 3:42 PM Post #3,211 of 3,520
Cut the wires with the connector from the original battery and solder it to the wires of the new one, not difficult if you know a little bit what you are doing.
The last thing I want to do in life is after buying a player for 3k$, solder a connector to the battery.
May 13, 2023 at 3:01 AM Post #3,215 of 3,520
Did Lotoo ever release a FW update where one can search be genre, or does this still have to be carried out at a folder level?
Lotoo devices did not have firmware with search and sort by genre.
May 16, 2023 at 6:44 AM Post #3,223 of 3,520
LPGT Ti incoming; of which, is there any advantage in using a full size 1tb San Disk Extreme Pro vs 1tb San Disk Extreme Pro MicroSD with San Disk adapter?
I haven't had a chance to compare, but I use a Sandisk 1Tb with an adapter and have no problems. Unless you need to leave about 1-2 GB of free space for everything to work properly.
May 17, 2023 at 8:56 PM Post #3,224 of 3,520
To conserve battery health, I always avoid charging beyond 80%. When connecting my LPGT to a computer as USB DAC, the battery is charging.
I have yet to find the setting to keep this from happening. I just find it impractical if I have to unplug it every time the battery reaches 80%.
So I if keep using LPGT as USB DAC until the battery is fully charged, how is this gonna affect the battery health in long term?
Didn’t you try to choose ‘USB DAC (Phone)’ mode instead of ‘USB DAC (Computer)’ one while connecting LPGT to computer?
May 18, 2023 at 5:16 PM Post #3,225 of 3,520
I have LPGT TI and i like a lot
Today i was in Munich with my Aroma Jewel with First Time and was courious to listen A&K sp 3000
I listened 20 minutes and i was very disappointed
For me Lotoo sound much better,more neutral and transparent and then with LPGT TI i listen at volume 45/50 on 100
While with sp 3000 to reach same level i have to go to 130 on 150
Very disappointed pn sp 3000
