F700
anyone thinks lotoo will release a new player with the new ak4499ex dacs?
ah no local playback?I think so, via USB Type-C PD
With the simplicity and stability of Lotoo OS this could be the next thing I didn't know I needed. Intriguing.I think so, via USB Type-C PD
What do you mean by local playback? The complete armada of connections in the back should allow pretty every kind of playback.ah no local playback?
ah i meant able to load an sd card and use the player like a dapWhat do you mean by local playback? The complete armada of connections in the back should allow pretty every kind of playback.
Yes you can. You have a sd-card slot on the front side.ah i meant able to load an sd card and use the player like a dap
I thought you meant as an internal storage. That we don't know, but there is definitely microSD card slot on the front and the top looks like an integrated LPGT. Don't believe this is Android dap, more like a transportable battery-powered LPGT on steroidsah i meant able to load an sd card and use the player like a dap
It would be great if it was a fully portable LPGT of the next generation.I thought you meant as an internal storage. That we don't know, but there is definitely microSD card slot on the front and the top looks like an integrated LPGT. Don't believe this is Android dap, more like a transportable battery-powered LPGT on steroids
I hope Lotoo will release the next portable LPGT.anyone thinks lotoo will release a new player with the new ak4499ex dacs?
