Lotoo PAW Gold Touch - Touchscreen, 4.4mm Bal, USB DAC, Bluetooth
Apr 19, 2018 at 11:12 AM Post #331 of 3,520
I STILL haven’t found any opinions on the Lotoo PAW Touch, except on passing sentence a page or so back by @Mimouille . Did I miss a longer review somewhere? Thanks!
The product is not released yet, it was only announced. The firmware is not even finalized, though hardware should be final. Once it will go on sale in a month, you will get some impressions from China (the only place it will be released for now).
Apr 21, 2018 at 5:44 PM Post #334 of 3,520
Guys, I just want to say this seems like a great player, but it is hard to say anything too definitive on a first try.
Thank you for taking the time to go audition it and for sharing your impressions!
Apr 23, 2018 at 5:09 PM Post #335 of 3,520
A quick comparison chart between the Lotoo Touch, SP1000 and 1Z. Let me know if it needs correction or if I missed something.
Apr 23, 2018 at 6:55 PM Post #336 of 3,520
According to the above numbers, the Touch shall have better resolution and better soundstage in comparison to SP1000. That is impressive. What is not as impressive is that SP1000 is worse in SNR (dynamic range) and higher cross talk, than even DX200 and Amp1. Not to mention the new amp modules
Apr 25, 2018 at 1:44 AM Post #338 of 3,520
This is where it is confusing. Crosstalk is good when it is more negative like -142db VS -129Db. This means the higher number, the better. The charts above is in positive number , and the higher the number is worse. But you are right, It seems the chart above about crosstalk should be (-)
Apr 28, 2018 at 1:19 PM Post #339 of 3,520
What is this LPG2? :) It's written that it comes with a different chassis and component material.
Anyway, finally got to try the LPGT. :D
Keep in mind, this is an engineer sample. Here is my brief impression. Comparing it with SP1000, and Zeus-R.
The LPGT is blazing fast. Fast boot (~2 seconds), responsive UI. But sometimes too responsive, as scrolling a long playlist occassionally it scrolled too fast. So touch more gently. Little hiss with the Zeus, but still a bit more in comparison with the SP1000. Note that it was with SE output. The balanced according to specifications seems more silent. Couldn't confirm. With the Zeus I got to a similar volume level with SP1000 at around 50-55. Both sound highly detailed, and resolving. The LPGT I felt was slightly brighter. It has a leaner note size, and crisp, higher treble. Soundstage I felt was more spacious with the LPGT, while the SP1000 is closer, and more intimate. Female vocals sounded sweeter, and clearer with the LPGT, while with the SP1000 it's warmer, denser, and somewhat more emotional. LPGT I felt was a bit more analytical, and less smooth. Not necessarily harsher, but it wasn't as forgiving, gentle and smooth as the SP1000. Details are more apparent with the LPGT though. YMMV.
I also got try the KSE1200 along the way. Beats whatever IEM I've heard in terms of resolution. I want one :) Especially now that the price is US$1000 lower than the KSE1500. I'll probably wait for a used set though, as I'm good with the Zeus for now. The KSE1200 is really good, clear superb high resolution. Pure realistic balanced neutral reference sound. Lovely extended treble, and accurate mids. Forgiving, and not harsh anywhere. Bass hits with enough strength. Note size is just right, and its stage clean. Some bassheads may find its bass lacking though, but it's just the good amount for me. Soundstage is big but not distant, close but not intimate. Vocals articulate, and perfectly positioned/centered. Maybe less warm, and emotional than the Zeus, but it's so realistic.
Apr 29, 2018 at 1:06 AM Post #341 of 3,520
Oops. Hey @ranfan , I just realized I had accidentally added a “NOT” in the sentence of my previous post, that completely inverted the message I was intending to convey. I have corrected it now. Or to be short, my next item of interest is the KSE1200. :)
Apr 29, 2018 at 1:32 AM Post #342 of 3,520
I caught that, but didn't have time to bring that up to you :)
