Nov 18, 2012 at 2:42 PM Thread Starter Post #1 of 5
Luke95
I listen to pretty much every genre except rap not so much. Need something that'll handle hardcore to metal to rock to electronic etc.
I don't know much about headphones / earphones so I need help. My budget is 100 dollars. My choices so far have been Sol HD amps which I'm able to get for 59.99 ( vs the regular price of 99 dollars ) or the Shure SE215... at the moment I'm leaning more towards the Shure SE215 after reading reviews of the Sol HD amps... but is the sound quality of the Shure worth 40 dollars more? I'm looking for any suggestions, if you know any in ears that are better than the ones I mentioned for the genres I listen to and fit my budget then let me know, thanks.
Nov 18, 2012 at 3:10 PM Post #2 of 5
If you are looking for more bass then JVC FX3X, Turbine, SE215, Sony XB90(highly recommended), Panasonic HJE900 are great buy and for more balanced sound HF3, RE0 are amazing(superbly detailed and offers good bass response).
Nov 18, 2012 at 6:23 PM Post #4 of 5
Hippo VB or Fischer Audio Silver Bullet
