techenvy
- Sep 23, 2009
I have no info on that subject I'm afraid.
I have owned many belt drive TTs over the years inc models from Dual, Linn & Rega. They all broke down sooner or later whereas the Technics I bought over 20 years ago are still going strong with v. little maintainence. Simple decision really. If it ain't broke don't waste money on it.
Yes. Despite it's good reputation in audiophile circles it is a little noisy. About 3dB random noise at variable frequencies below 150 Hz. So you cannot really hear it unless you turn the gain way up with no program material but it's annoying knowing it is there and worse than either my old mixer or receiver/amp phono stage, Which are MM only btw so don't need as much gain.
To be fair to Cambridge Audio once I proved it to them ( I have fairly sophisticated signal analysis software courtesy of the MOTU) they exchanged my unit. Unfortunately the replacement was just as bad. Perhaps I was just unlucky and there was a bad batch imported into the country. I plan on leaving it for a while then trying another replacement and if that does not work then buying an alternative. Probably battery powered as it's usually the power supply that is at fault.
Possibly this one. http://www.aqvox.com/phono.html
hi ronald,
well you were right about the the cam 640p, it was better than my reciever's crap phono, but it sure the hell isnt quite, not super noisy or anything but i was expecting much more, having said that i may hold on to her for a while,, i only have trouble when listening wit phones, but i am very very picky. it is nice having two inputs for mm and mc, so i can hook up both tables with different carts and switch nearby. if she was cheaper i could justify her, but not at that price/performance.
but i may just jump right off into the deep end. there are way too many preamp/phono stages to choose from.
cheers for the heads up bro
