FallenAngel
The 2 275Watt RMSsubs running off the amp bridged to output 400Watts RMS, you're running with quite a few more watts than required. As long as you don't overpower the subs by much, sounds like a nice setup.
Originally Posted by FallenAngel The 2 275Watt RMSsubs running off the amp bridged to output 400Watts RMS, you're running with quite a few more watts than required. As long as you don't overpower the subs by much, sounds like a nice setup. |
Originally Posted by soloz2 Woot! I got a job, so I'll probably order the parts for the amp and power supply next week |
Originally Posted by mb3k Muahhaah! Dedicate >50% of your profits to DIY. |
Originally Posted by FallenAngel 1) AD8620/AD8610 sounds very detailed and sounds great, I liked those chips in mine before I fried the AD8620, now I'm using AD8066/AD8065 and they sound pretty damn good too at less than half the price. 2) For the OPA627 you'll need 3 chips, I haven't heard them so I can't say what they sound like. Question 2) DIP8 is bigger, SOIC8 is surface mount and you'll need an adapter to put it in the Pimeta. I would say need because you don't want to be soldering chips to the board in case you screw up or you want to change the chips later. You'll need some DIP8 sockets, solder those on and you're good to go. So as for which is better, DIP8 is definitly what I would go with. Question 3) Up to you completly, if you don't want to use the power switch built in to the Alps, don't use it, wire another one. --- As for these FET/RFET/ZNR, since you're planning to run this off the TREAD, just go with an RLED and that's it. You don't need to worry about having an LED shut off when batteries are low, so you'll never use this. |
Originally Posted by FallenAngel The AD843 has pretty boomy bass, so consider it if you like lots of bass, but I found it much less detailed than AD8620 or AD8066. |
