JamminVMI
Neither my Asgard 3 nor Lyr 3 have any noticable noise with Loki or Lokius either.Magni likely doesn't have enough power to notice tbh
Turning the #3 to #5 controls to max though, induced hiss in the middle position of the volume. Testing with music with Sennheiser HD650 showed that was about 10 to 20% higher than the max volume I wanted to listen to so I don't think it is a problem. Noise was much more audible with pair of Dan Clark Stealth and Ether CX headphones
Controls 4 through 5 caused hiss in content and any distortion to get magnified. You would not want them more than 10 to 20% boosted.
It would be interesting to see pics of the 4 pots used by Loki Minis out there.
The keywords on my post are [Lokis] out there. Not the manufacturer’s photos. The user’s units being used and pots set.what would you like to see?
My pot adjustments are, whilst not all over the map, are pretty varied. It really depends on the headphone I'm using, and what I'm listening to. Right now, at my desk (Loki+, Bifrost OG 4490, Asgard 3 with DCA Aeon RT Closed), I'm running (from L to R), 2:00, 10:00, 10:00, 12:00). Listening to Lissie and Eva Cassidy.The keywords on my post are [Lokis] out there. Not the manufacturer’s photos. The user’s units being used and pots set.
Like this (small adjustments here):
P. S. - saw your posts re device noise. None on mine. Either your unit is defective or conveys noise from some other source.
Does anyone elses Loki mini+ produce a lot of heat? My Modi+ is stone cold, Magni+ and Heretic are barely warm. Loki, hot.
OK, I can put my hand on it and not have to remove it. I find it odd that the warmest piece is the EQ not the amp.Hot is relative, but nicely warm (not scalding) is normal.
I have the Loki Mini+ too. I had contacted Schiit about the heat from the Loki. They said it’s normal for it to get very warm and sometimes hot, but it won’t cause any problems.Does anyone elses Loki mini+ produce a lot of heat? My Modi+ is stone cold, Magni+ and Heretic are barely warm. Loki, hot.
