All this serious conversation in this thread... let's have some fun!
Post your EQ settings! I don't care which portable player/audio program you're using, just post what you have! If it's not a default setting; do the best you can! I'll start...
... I'm finding that the "Electronic" setting on iTunes and the iPod Classic does a good job bringing out the mids and bass without distortion! It's almost a Shure sound, except in a custom! C'mon, everyone! Let's do this!
_______
While we're on the topic of EQ and specific frequencies, I'd also like to take this opportunity to perpetuate and share (with anyone who hasn't seen it) what has been, in terms of mixing, the most useful piece of text I have come across yet:
I have found the following to be very helpful information when mixing live and eq'ing music to my personal tastes. I find that creating custom (I understand that many personal players dont allow this) "mixes" according to music types can get you close to what you want with very little adjustment. Knowing where the instruments you like to hear really helps you setup for your ear. Hope someone finds this helpful. I don't take credit for it - you can find this information all over the web.
FREQUENCY:
USES:
50Hz
1. Increase to add more fullness to lowest frequency instruments like foot, toms, and the bass. Peak equalization with a 1.4 Q.
2. Reduce to decrease the "boom" of the bass and will increase overtones and the recognition of bass line in the mix. This is most often used on loud bass lines like rock. Shelf equalization.
100Hz
1. Increase to add a harder bass sound to lowest frequency instruments. Peak Equalization with a Q of 1.0 to 1.4..
2. Increase to add fullness to guitars, snare. Peak Equalization with a Q of 1.0..
3. Increase to add warmth to piano and horns. Peak Equalization. For piano use a Q of 1.0. With horn use a Q of 1.4..
4. Reduce to remove boom on guitars & increase clarity. Peak Equalization with a Q of 1.0 to 1.4..
200Hz
1. Increase to add fullness to vocals. Peak Equalization with a Q of 0.7 to 1.0..
2. Increase to add fullness to snare and guitar ( harder sound ). Peak Equalization with a Q of 1.4.
3. Reduce to decrease muddiness of vocals or mid-range instruments. Peak Equalization with a Q of 1.0.
4. Reduce to decrease gong sound of cymbals. Peak Equalization with a Q of 1.0.
400Hz
1. Increase to add clarity to bass lines especially when speakers are at low volume. Peak Equalization with a Q of 1.0.
2. Reduce to decrease "cardboard" sound of lower drums (foot and toms). Peak Equalization with a Q of 1.4.
3. Reduce to decrease ambiance on cymbals. Peak Equalization with a Q of 0.7 to 1.0. Alternately try a shelf EQ with a 320 Hz frequency setting.
800Hz
1. Increase for clarity and "punch" of bass. Peak Equalization with a Q of 1.4.
2. Reduce to remove "cheap" sound of guitars. Peak Equalization with a Q of 1.0.
1.5KHz
1. Increase for "clarity" and "pluck" of bass. Peak Equalization with a Q of 1.4..
2. Reduce to remove dullness of guitars. Peak Equalization with a Q of 1.0.
3KHz
1. Increase for more "pluck" of bass. Peak Equalization with a Q of 1.4.
2. Increase for more attack of electric / acoustic guitar. Peak Equalization with a Q of 1.4.
3. Increase for more attack on low piano parts. Peak Equalization with a Q of 1.0.
4. Increase for more clarity / hardness on voice. Peak Equalization with a Q of 1.0.
5. Reduce to increase breathy, soft sound on background vocals. Peak Equalization with a Q of 1.0.
6. Reduce to disguise out-of-tune vocals / guitars. Peak Equalization with a Q of 1.0.
7. Increase for more attack on the snare or other drums. Peak Equalization with a Q of 1.4 to 2.8.
5KHz
1. Increase for vocal presence. Peak Equalization with a Q of 1.0.
2. Increase low frequency drum attack ( foot / toms). Peak Equalization with a Q of 1.4 to 2.8.
3. Increase for more "finger sound" on bass. Peak Equalization with a Q of 1.4.
4. Increase attack of piano, acoustic guitar and brightness on guitars (especially rock guitars). Peak Equalization with a Q of 1.4.
5. Reduce to make background parts more distant. Peak Equalization with a Q of 1.0.
6. Reduce to soften "thin" guitar. Peak Equalization with a Q of 1.0.
7KHz
1. Increase to add attack on low frequency drums ( more metallic sound ). Peak Equalization with a Q of 1.4 to 2.8.
2. Increase to add attack to percussion instruments. Peak Equalization with a Q of 1.4 to 2.8.
3. Increase on dull singer. Peak Equalization with a Q of 1.0.
4. Increase for more "finger sound" on acoustic bass. Peak Equalization with a Q of 1.4.
5. Reduce to decrease "s" sound on singers. Peak Equalization with a Q of 2.8. Sweep frequency slightly (between 7 kHz and 8 kHz) to find the "exact" frequency of the S
6. Increase to add sharpness to synthesizers, rock guitars, acoustic guitar and piano. Peak Equalization with a Q of 1.0 to 1.4.
10KHz
1. Increase to brighten vocals. Peak Equalization with a Q of 1.0.
2. Increase for "light brightness" in acoustic guitar and piano. Peak Equalization with a Q of 1.0.
3. Increase for hardness on cymbals. Peak Equalization with a Q of 1.4.
4. Reduce to decrease "s" sound on singers. Peak Equalization with a Q of 1.4.
15KHz
1. Increase to brighten vocals (breath sound). Peak Equalization with a Q of 1.0.
2. Increase to brighten cymbals, string instruments and flutes. Peak Equalization with a Q of 1.0.
3. Increase to make sampled synthesizer sound more real. Peak Equalization with a Q of 1.4 to 2.8.
cleen version
useful frequencies for several instruments:
Voice: presence (5 kHz), sibilance (7.5 - 10 kHz), boominess (200 - 240 kHz), fullness (120 Hz)
Electric Guitar: fullness (240 Hz), bite (2.5 kHz), air / sizzle (8 kHz)
Bass Guitar: bottom (60 - 80 Hz), attack (700 - 1000 Hz), string noise (2.5 kHz)
Snare Drum: fatness (240 Hz), crispness (5 kHz)
Kick Drum: bottom (60 - 80 Hz), slap (4 kHz)
Hi Hat & Cymbals: sizzle (7.5 - 10 kHz), clank (200 Hz)
Toms: attack (5 kHz), fullness (120 - 240 Hz)
Acoustic Guitar: harshness / bite (2 kHz), boominess (120 - 200 Hz), cut (7 - 10 kHz)
