MIKELAP
If you want general infos about amps http://littledot.net/Hello, does anyone know the official little dot website url? can't find it on google..
thanks
thanks
Low Z planars don't really pair well with OTL amps, you get bass roll off. The T50RPs really shine with an amp that can put out 1W or more. If I do get another solid state amp it will be the Emotiva BasX A-100 to bring my Fostex to life.yeah I tried the 1770pro and just couldn't get on with them, so then got the foster 610's which I also didn't get on with. So I decided to try the 1990pro's which I read great things about,. to my dismay I dint like these either, so I figured I didn't like the byerdynamic sound. So I thought I would try the hd6xx as they are so highly spoken about. When pairs with the little dot they really are great (personally ) it just made sense, sweet low end great mids and instruments and female vocals just popped with all the detail and texture I was looking for. I have started rolling the power tubes and realised they really effect the overall presentation and details of the music. The adventure continues!
I was eyeing up the t60rp the other day, they look very attractive for the money the t50rp also look really nice. maybe I should try planar with the little dot mk2 .
Yeah, it's been a long while. It seems like they have not done any marketing for a long while. I found out about the new site couple of weeks ago, and they've got quite a line of interesting products.That's good to know, they have been gone a long time.
Thanks for the heads up! I picked up a pair of t60rp last night, should arrive today. Will see how they behave on LDMk2 plus as-701.Low Z planars don't really pair well with OTL amps, you get bass roll off. The T50RPs really shine with an amp that can put out 1W or more. If I do get another solid state amp it will be the Emotiva BasX A-100 to bring my Fostex to life.
Also, stock T50RPs sound horrible out of the box, they have to be modded. Get yourself a pair of Argon's that already have the modding done.
https://www.modhouseaudio.com/
Nice! I do love the look of the T60RP and would like to get a chance to hear them one of these days, Fostex makes great heaphones.Thanks for the heads up! I picked up a pair of t60rp last night, should arrive today. Will see how they behave on LDMk2 plus as-701.
So, yeah i am impressed, definetly more high end and low end, really nice to listen to in fact and i have to say you are right! They sound a lot better on my as-701 vs LDmk2. And they really highlight the HD6xx deficiencies in the high and low end. I am really struggling to find an issue with the them. defo take more juice, and dont run so well on valve amp. very clean sounding, but still musical. very nice! think i will be keeping theseNice! I do love the look of the T60RP and would like to get a chance to hear them one of these days, Fostex makes great heaphones.
Awesome! I love my planars and wouldn't give them up for love nor money.So, yeah i am impressed, definetly more high end and low end, really nice to listen to in fact and i have to say you are right! They sound a lot better on my as-701 vs LDmk2. And they really highlight the HD6xx deficiencies in the high and low end. I am really struggling to find an issue with the them. defo take more juice, and dont run so well on valve amp. very clean sounding, but still musical. very nice! think i will be keeping these
(sorry for going off piste with the thread)
If you change around the tubes does the hum follow to the other channel? i dont remember my homemade adapters ever having a humOK, so my C3Gs and adaptors arrived. Put them in my LD mk2 and got a mind-bendingly loud buzzing from the left channel. So took advice from some of the earlier posts on here and changed the gain settings from "3" (which I normally use) to "5". Buzzing disappeared and the tubes sound pretty good. However there is a definite background hum which I have not noticed before. Swapped the C3Gs out for some Mullard 8100s and the hum is still there (although not quite as loud). Is this just the gain change that has caused the hum or is it something I should worry about. If this cannot be cured I may have to try going back to Gain "3" and see if it disappears. Sad, if that's the case, as I love the sound of the C3Gs but not sure if I can live with the hum, particularly on quiet tracks. Any advice much appreciated.
The hum is on both channels. The deafening buzzing was just the left channel.If you change around the tubes does the hum follow to the other channel? i dont remember my homemade adapters ever having a hum
Could problem be adapters ?The hum is on both channels. The deafening buzzing was just the left channel.
Possibly Mike, but there seems to be a slight hum now when using the Mullard 8100s. It's not earth-shattering, but I notice it in the gaps between notes on quieter pieces of music. Maybe it is just something that I am only just noticing now that I have the Gain up higher than normal. And I really like your adaptor tutorial by-the-way. One day I may attempt it when I'm feeling more confident!Could problem be adapters ?
If you have the Mk-2, I can wholeheartedly recommend a pair of Brimar 6SN7GTs with adaptors. Ive been running NOS Sylvanias and loved them till I picked up the Brimars. Very warm with silky vass.Could anyone recommend a good power tube, i have stuck with the 6n6p novosibirsk gold grid since i got the amp.
Thanks
Try some 6SN7GTs with adaptors. A matched pair of Russian 6H8Cs are nice as are Sylvania 6SN7s I'm running Brimar 6SN7s at the moment and they are truly gorgeous sounding.what power tubes should i get for my LD Mk II? currently i have Mullard m8100, Voskhod 6ZH1P-EV and GE JAN 5654W
