Little Dot Tube Amps: Vacuum Tube Rolling Guide
Feb 16, 2015 at 12:28 PM Post #9,121 of 13,448
OK...Small update on the C3G...There IS output...very, very low...volume pot turned to MAX???
Should the C3Gs be set to EF95 or EF92?
What would a gain issue point o with these tubes???
TIA
-Mark
Feb 16, 2015 at 12:43 PM Post #9,122 of 13,448
Ok...Finish this conversation with myself...Obviously EF95 setting is correct.  I have output now.  Had to play with the tubes in those cheap Chinese socket though.  Basically, can't touch the adaptors/tubes or they cut out...assuming the crappy pins.
Guess I'll order some NOS or maybe some of those Russian sockets Mike got.
Anyone tried these?:
http://www.ebay.com/itm/Cinch-NOS-Vintage-Loctal-Loktal-8-pin-tube-socket-/400772825220?pt=LH_DefaultDomain_0&hash=item5d4fec0084
TA
-Mark
Feb 16, 2015 at 2:01 PM Post #9,123 of 13,448
These Amphenol's might be your best bet for a decent socket.
http://www.ebay.com/itm/NOS-Amphenol-8-Pin-Loctal-Loktal-Tube-Socket-for-7N7-7AF7-type-tubes-/221681170614
Feb 16, 2015 at 2:36 PM Post #9,124 of 13,448
TA
-Mark
Glad you finally sorted it Mark...yes, those particular sockets do leave a lot to be desired, lol!
Feb 18, 2015 at 7:11 AM Post #9,127 of 13,448
  Sent my LD I+ for repair yesterday. Still can't figure out why they have buzz and noises.
Little dots are known to pick up interference , my mkiii is dead silent most of the time, but occasionally it'll pick up some noise
i had a I+ that was silent all the time, and one that was noisy as hell, and not matter what i did, stayed that way
good luck !
Feb 18, 2015 at 10:52 AM Post #9,128 of 13,448
good luck !
well, it wasn't the mkiii at all, it was one of the 6hm5's being a little noisy, and that just developed
i put in my mullard 6ak5's, -silent
Feb 18, 2015 at 3:47 PM Post #9,129 of 13,448
Hi folks,
Could do with some advice please.
I bought the following EF95 tubes for my Little Dot Mk1+
http://www.ebay.co.uk/itm/251789963059?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
However I've noticed a reasonably loud humming noise coming from them even with the volume on my Little Dot turned down.
I'm under the assumption no jumper settings need changing with these, as they are EF95's, so have I bought duds?
Cheers
Feb 18, 2015 at 3:57 PM Post #9,130 of 13,448
They might be duds, but most likely there is nothing really wrong with them. New tubes often buzz and hum, so run them for 20 hours or so, and see if they don't quiet down.
Good luck! :)
Feb 18, 2015 at 6:40 PM Post #9,132 of 13,448
Thanks for replying
Does this apply to 'old' new tubes? These were supposedly made in the 60's.
Also do I need to have music playing through them or is just having them switched on enough when burning in?
Yes. Even though these Russian tubes were manufactured in 1966, they have never been used. Again, new tubes, tubes that have never been used, need to be burned-in. And it doesn't matter if they were manufactured in 1945 or 2015. :)
It is generally considered best practice to have a set of headpones plugged in when any amp is on, but not when turning it on or off. That is, it is best to turn an amp on, wait a minute or two, and then plugin the phones. And likewise, unplug the headphones first, and then turn the amp off. This protects your ears and your headphones in the event that the tube fails catastrophically. Further, I always use a very cheap pair of headphones when burning in new tubes.
I am not sure that it is absolutely necessary to run a signal through them, but I do.  I like to be able to listen every several hours or so, to see if they tubes are quieting down. I just run a CD player on repeat.
Feb 20, 2015 at 2:05 AM Post #9,135 of 13,448
My LD I+ came with 6cq6 tubes, but one of the 2 went dead after I moved house, so I bought Mullards CV4010 to replace them instead. It would be worse if the tubes caused the buzz, cos I bought them in Singapore and won't return to the country in the near future... Damn
