kvtaco17
- Mar 29, 2013
Hi Guys,
I just received my Raytheon JAN-6832 Please show me the PIN Layout for this tube.THANK YOU!
Hi Guys,
Well I jacked that up...
1 = a
2 = g2
3 = h
4 = k
5 = k''
6 = h
7 = g''
8 = a''
from the above pic...
Is this the right way to wire 6832 to 6SN7?
6832 6SN7
Pin 1=A pin 2
2=G2 1
3=H 7
4=K 3
5=K" 6
6=H 8
7=G" 4
8=A" 5
I wired my adapter like this and it's only working with Left channel.
6832 6SN7
Pin 1=A pin 2
2=G2 1
3=H 7
4=K 3
5=K" 6
6=H 8
7=G" 4
8=A" 5
Looks right to me
This looks fine to me. And I am assuming that you remembered that when looking down into the octal base, the pins are numbered 1 -8 counting counter clockwise.
If you are building an adapter similar to mine, the only things I can suggest is to make sure that you don't have any wire leads touching, your solder joints connecting the leads to the 12 gauge wire posts are good, and the posts are making good contact inside the octal base. You might want to pull out your multimeter and check continuity from the octal pin to the wire lead for each element.
Good luck!![]()
No luck selling the LD yet so I unpacked it this morning and now I'm considering keeping it again!![]()
Wanting to try the C3G upgrade. Found a few online for under $50. @gibosi can you chime in on the difference between C3gs, C3g, and C3m?
I finally got it right and this tube (6832) it sounds nice.....![]()
