TrollDragon
Hey MIKELAP, I was just reading about that over on DIY Audio.
The Pre Out of the LD I guess is very poorly designed. What I gather from reading is if the LD blows a tube there can be over 100V DC dumped out the Pre Out jacks, I had a look at the schematic for the SX750 and there are caps on the Aux In at the input opamps but it is a low value and only 25V.
So this is the dilemma, you can hook it up and as long as you don't have a bad tube all is good and it could last for years. The moment the tube goes bad and it starts dumping out DC that little 25V cap is not going to save the the SX750, smoke will roll and most likely your speakers with it.
What some have done is installed blocking caps on the inputs inside of their speaker amp as there is no room in the LD. They install 500uf 250V caps on the input line which will safeguard against a failure, but these caps are huge and $40 each.
It might be something to consider, but I would consult with someone who has more electronics knowledge than I have.
A Russian Roulette with your speaker system IMHO is just not worth the chance.
