Pricklely Peete
Franken modder
- Feb 17, 2008
Well, hearing is subjective after all. If it works for you..it works for you.
I disagree completely with your opinion about the 6H30's. I find mine work wonders over the stock tubes. I've also modified my MK III a little more than most folks, the mod having a very positive effect revealing details, nuance, lowering the noise floor, better bass (tighter), more focused mids.....slightly wider sound stage.This is with Sylvania,Tung Sol (EF 95's) and Mullard (EF 92) drivers into a pair of NOS 6H30Pi-DR's. If you thought the Golds were expensive
You've talked about the power tubes...what driver tubes are you using ?
These really can make or break the amps overall SQ.
Peete.
Originally Posted by One Fan To Another /img/forum/go_quote.gif Oh, I'd like to add: The best thing I did for my headphone setup was add a BBE Sonic Maximizer. Forget tubes for a second, for less than the price of a couple pairs of EH 6H30Pi tubes you can get a Maximizer off of eBay and get a far superior and much more palpable change in you sound. I can't use my headphone setup without one at this point. |
Peete.
