So as they now worked in my system I'd rank them as follows: First, Audio Note Niobium non-magnetic - these are worth their price here and they are in a different league to the rest. Second, the Kiwames - they have good punchy and deep bass and are relatively cheap too even if they don't have the very best clarity. Third, the AN tantalums which had many things in common with the Kiwames but were worse. Fourth the TKD metal films which have a crisp character but are low on bass. Fifth and last the Ohmite Audio Golds which didn't really stand out with their characteristics
This is excellent info! Good work!
Do the WCF caps need to be "audio caps" or just have the best electrical properties for power delivery - (how much) does the audio signal pass through them?
Yes as
@baronbeehive stated very well, they are smack in line between the output tube triodes, so they need to be quality.
A good point was made about the capacity. We have not tried larger WCF caps. What size are yours. I only tried .33uf, but according to Baron, we might see current gains with larger size, although I do believe the current is mainly a tube limitation.
Also, what about the eight small Wimas that are located between the power tubes and PSU section? At least some people have replaced those with something else, such as the Mundorfs
here. Is their function power delivery or something else?
Those are strictly PSU caps design to keep the circuit from having any noise like hum or oscillation. They will not affect sound, only isolation.
Would the opamps' biasing function somehow rely on feedback from the headphone output? And if yes, could it be that having the impedance matcher attached somehow cancels some of this?
Nope. Opamps only affect DC-offset, which would result in a pop sound (when headphones insertion) if they were off by any small amount.
I've been looking into this too. This effect happens with the B10 impedance matcher connected regardless of the tubes. At startup the vu meters both show 60 ma, but the left then begins slowly approaching 40 ma or lower and the right side begins approaching 80 ma or higher. This doesn't fix itself (but instead gets worse) if I leave the amp running for a long time. It also happens only with the impedance matcher attached, and is reset (so that the readings are 60 and 60) if the amplifier is turned off and on again
My guess is that the tubes are having a bad reaction and causing the meters to slowly change.
Check for tube thermal runaway by swapping tubes to other meter(other side).
That may be a bad idea to put film caps where the 4 big PSU electrolytics are..
The reason is that we do not want such a fast load on the bridge Rectifier. This is why there are those huge resistors under PSU section, to absorb the current surge when you turn on the unit...
I thought it was established early in the thread that the opamps are used for biasing here?
And that the blue trimpots are there to set some sort of starting point for the biasing, which will be affected by feedback from the output? (Is any of this correct?
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
And if so, would the values from the trimpots somehow be multiplied or magnified in absence of normal/expected feedback from output?
In that case, some sort of imbalance in the trimpot adjustments could cause growing imbalance in the meters and also be redeemable by adjusting the trimpots.
But I don't know how to adjust the trimpots... how should that be done?
Check the schematic and you will see it does take a bit from the outputs as there is a very high value resistor at the output (on the board). This DC-offset it critical, as if it was off by a large amount (enough to move meters), then it would create a loud pop and trigger the output relays.
So this is not happening and most likely no one ever has to adjust the trim pots.
It can be "fine-tuned" if you hear a tiny click/pop when plugging in headphones, but try it after it is warmed up, not when just turned on as that's when circuit settles.
Edit: This may also explain why the Impedance matcher didn't work on the LD
I don't know why, but I have permanently installed different anode resistors to my output tubes to change the impedance out from a calculated 600 ohm to a 50ohm headphones impedance, so the calculations to change output impedance work.
It changed the sound of a stock HD800 from a more mids, to a bit recessed mids, which is how it sounds with solid state.
At the time I changed my amp, It was tuned for the "Ether" planar, which was around 50ohms. So output was calculated for a 50 ohm load.
What impedance load have you tried set it to? It cannot be zero as it must optimally be the setting of the headphones impedance.
I thought the mk6 was already set for around 50ohm load?
