sound came through to headphones but at a very low volume.
That's the driver stage your hearing and a good sign only your output stage is off. Most likely cause you already pointed out is the PSU.
No prob, It needed upgrading anyways.
Re: the lack of sound, the current surge could have triggered the headphone protection circuit
For sure the output stage is not working, and most likely due to the power supply failure.
The protection circuit can also be enabled because of this.
Yes I would definately advise to change the transistors as well as the originals were prone to failure with increased loads
Yes and as I recall, the diodes die first, causing the transistors to die next.
Hopefully they didn't blow if he caught in time.
Edit: reading back on the thread, there were advice also to replace the PNP / NPN transistors in cases where those two blue resistors were burned
I was going to replace mine, but I haven't, as they didn't blow up on me yet.
They blow up easier and are obsolete and mouser parts have the updated version which will not easily die.
I would advise to first change the resistors and
especially the diodes, because the transistors will die again if those cheap diodes are dead, as usually the case.
For the diodes, get higher rated wattage, but same voltage. I believe they were 100v, and you can even add two in parallel for better heat dissipate and better current.
So regardless of the burnt looking resistors, which most probably went up in value, you must change the diodes which are first to blow and cause the transistors to go right after.
If your lucky the transistors are ok but would need to check on a multi meter with a transistor tester built in.
That's allot of trouble to take out, so try the diodes first, and if the resistors start to cook, your know it's the transistors.
You must buy as a set of two (pnp& non)
Another BIG issue is that upon moving the board, it is booby-trapped with garbage tin wires that run from the board to the transistors (located on unit body ).
TAKE PICS to remember and replaced these short wires as it is essential. They break off easily and then sparks fly!
Even when hit or board closed, they can just call off thru vibration. They crumble because they're brittle, like stranded tin. Just replace them.
