1- I plan to upgrade the cathode caps to to Nichion KZ / Muse at larger size so meters won't dip at high volume with planars (remember I have the lesser current MK8)
2- Then the caps WCF caps to jupiter (expensive) or actually the "Clarity Cap CMR
I finally got around to ordering replacement caps.
** Nichion KZ (1000uf)f replacement of my small cathodes.
I like the balance and extension of this specific electrolytic.
It doesn't need any help with any bypass cap.
** Audyn true silver for my WCF position caps.
I feel for this area of the circuit, we need a lively cap that is bright, fast, immediate and detailed and is
least thick or harmonic, so no copper or mix caps.
The WCF position is coupling and in between the triodes which react with each other, so a pronounced speed and clarity type of cap would be best.
I noted in the past that normal caps sounded thicker & duller here, so it is more critical to get a brighter and lean cap( least harmonics added sounding) cap.
This is the weakness of old school designs.
That you must know about the parts you put in, to a specific area, which is like choosing ingredients to a chef.
An experience designer in this type area (where parts are critical to sound) would know which brand caps or other parts to use.
