baronbeehive
This is a pic of my mods to show how everything fits:
The guy who made the thread.Redge???...... who????
BTW have you seen this: http://www.humblehomemadehifi.com/Cap.html
It may help you make up your mind about caps.
Well isn't that interesting.
Someone that doesn't have the 5998 bias mod in place try out this configuration and let me know what you hear 6080/5998/6080/5998 left to right.
"edit" It looks like the distortion reduction may be assisted by the load dissipating around 1/4 less power due to the lower current in one of the follower stages, interesting how the distortion got cut by 65% and not 25%.
Nice website ! I wasn't thinking the Caps could be tested (in heard way) as tubes ! First for me.
Thank you for sharing
Anyone try the "Intertechnik Audyn True Copper Max MKP 630VDC - 2% tolerance" ?
Seems really close the Jupiter PIO for more than half the price, so could be really interesting ! Need x4 for coupling caps (driver stage <=> power stage ), and x4 for WCF coupling caps (inside power stage) ...
Nice peace of work ! impressive !
Did you remember what's stuff/composents did you use ?
The rules get thrown out when you mix tubes. I found the stock 6080WAs to sound superior when tube mixing in nearly all combinations, although mullards are also really good.
Rather then being bright the stock thomsons add low end heft and lushness to the sound.
I think adding 6as7 with the 5998s will actually be on the bright side but you can try both and see what you like more.
Unfortunately I've forbid myself from listening to my headphones until august to give me ear a chance to heal.
It was so loud it should have been illegal.That concert you went to must have been LOUD, sounds like you might have damaged your eardrums.
Yeah, they were what I was going to try but didn't because of the size. What I've heard is that they are practically as good as you say. I know Maxx has these in his other amp, so he might tell you, but they are BIG!
Thank you !Yes my parts list is on page 53.
Agreed about the tubes but I think 6AS7G RCA's might give the mellowness gug42 is after.
Edit:
I think you will find Sylvanias a bit on the bright side, TS5998's would be much mellower if you can get hold of any at a fair price.
Hmm, maybe its the difference in our headphones, mine isn't bright at all. Try mixing them like this 5998/6080/5998/6080. I encourage you to try with the 6as7s too.
Audyn Body dimensions: 30mm (diameter) x 45mm (length)
Jupiter Dimensions: 21mm (diameter) x 52mm (length)
Duno if it's a problem within the mk6 ... did it feet in the boxe ?!?
But Well did you have some caps in the same price range ?
