coinmaster
Two different mods, the 10M45S are an improved version of the "driver bias" mod.Then there is coinmaster's version of the impedance mod using the 10M45S parts
Although to have the ultimate upgrade to the driver stage you'd have to include a mu follower in place of the load resistors along with the 10M45S mod which is easy enough for anyone that wants to do it, I'd be happy to show you how, but I won't hold my breath. It seems like enthusiasm has waned for the MK6 mods.
The Improved "impedance mod" is a different beast.
The impedance mod doesn't match the impedance to a single headphone or lots of headphones per se. The WCF topology can only be optimized for a single load impedance in which the current sharing between both triodes are equal.which better matches the impedance to a whole lot of headphones at once I believe.
Unless you are using planar headphones this means that the existing impedance mod will not work throughout the entire frequency range, the goal of the existing impedance mod is to find the a sweet spot to try to hit as many frequencies at once as it can but dynamic headphones have varying impedance with frequency so it will never be optimal.
My improved impedance mod does a few things at once, it gives a lot better PSRR, lowers the input capacitance, and keeps the current through both triodes balanced no matter what the load is.
The end result being less loading on the input stage as well as improved sound throughout the entire frequency range.
