rudra
Has anyone got around to using a EL3N tube with adapter on the MK VI+. If some one has could you please chime in with your experience.
Can someone who has a Bendix or Chantham 6080WA graphite plates let me know what should read in mA. I purchased 4 tubes and I get different readings(one side reads 30 mA and the other side reads 60 mA). Also the protection circuit kicks in. It seem one or more tubes are bad. Trying to figure out how I go about identifying the dodgy ones.
FWIW my MK6+ reads around 38mA but I got the factory upgraded caps and my power tubes, WE421A/5998s are all matched within 3% Emission and Gm.
Inserting matched quad of TS7236s gives me the same result.
My drivers are Raytheon 5694s, National Union Sound X/tra 6N7Gs or Sylvania Metal Base 6SL7Ws.
I run my MK6 on low gain and it sounds fantastic with tons of power. I also run it with the Little Dot 500 power supply so between that and the factory upgraded caps is probably why my unit runs in the 36-40mA per channel range.
No issues at all and mine doesnt run at the usual 60mA.
The meters should read around 60mA. Try swapping, one tube at a time, from the 30mA channel to the 60mA channel. Then you'll see if you have one or two bad tubes.
You could also measure the voltage drop across the cathode resistors. That will tell you instantly which tube(s) are bad.
If the protection circuit kicks in the meters read 0mA, so I don't understand that. For a tube to trigger the protection circuit it needs to have a near dead short.
If you put some 6AS7/6080's in your amp they will run at 60mA. The cathode resistors sets the current of your output tubes, caps doesn't matter.
You can run your 5998/421A's at 60mA too with much improved SQ. I made a guide in the mod thread.
I found the offending tube. The problem is that when I replace the faulty Chatham with the stock tube both the meter read close to 62 mA but I get no sound from either the SE/Balanced output. I bummed as to why the sound is not coming. If I use the stock Thomson 6080WC or 7236 tubes the audio plays fine. When I use quad 7236 the meter reads 40mA on both sides. The stock tubes read about 62 mA.
Left meter reading:
Right meter reading:
@SonicTrance and @eserafinojr thanks for your advice. In the end it turned out that 2 out of the 4 tubes were dud. Disappointed(the shipping cost of the duds back to the USA from Oz is a real kicker) but the seller has agreed to replace.
BTW has anybody modded their MK6 to handle the extra current draw of the TS/Cetron or Raytheon 6336, 6336A, CK6336 or the 6528 power tubes?
They have the same pinout of the 6AS7/6080, run at 6.3Vs but draw much more current so I doubt the MK6 could handle them without frying it or shorting something!!
they are both 6080wb , so they have same specs, so i dont see a problem.
Also, I have experimented in past a mix which can be done , only when using same spec tubes:
what I would suggest, is to place one of each brand on same side(!)
the left (positive) socket of each side will provide the dominant characteristic of the pair.
This insight is from my testing.
Also suggest all to at least read the "supermod" thread just to at least gain insights on your amp inner workings...
